How to Use a Needle Threader
  1. How to Use a Needle Threader, How to Use a Needle Threader: step 1, image 1 of 2 How to Use a Needle Threader, How to Use a Needle Threader: step 1, image 2 of 2
    • Take the needle threader in one hand, and the needle in your other hand.
    • Insert the wire loop on the needle threader through the eye of the needle.
    Ask FixBot
  2. How to Use a Needle Threader: step 2, image 1 of 3 How to Use a Needle Threader: step 2, image 2 of 3 How to Use a Needle Threader: step 2, image 3 of 3
    • Hold both the needle threader and needle in one hand, while keeping the loop of wire on the needle threader through the eye of the needle.
    • Insert your thread through the loop of wire on the needle threader.
    • Pull the thread through the loop so that you have a tail of least a few inches in length.
    Ask FixBot
  3. How to Use a Needle Threader: step 3, image 1 of 2 How to Use a Needle Threader: step 3, image 2 of 2
    • Fold the tail over to meet the other thread.
    • Hold both lengths of thread together.
    Ask FixBot
  4. How to Use a Needle Threader: step 4, image 1 of 3 How to Use a Needle Threader: step 4, image 2 of 3 How to Use a Needle Threader: step 4, image 3 of 3
    • While holding both threads, pull the wire loop of the needle threader out of the eye of the needle.
    • Once the wire loop is out of the eye, release the tail end of the thread.
    • Pull the needle threader off the thread. This will bring the tail end through.
    Ask FixBot
  5. How to Use a Needle Threader: step 5, image 1 of 3 How to Use a Needle Threader: step 5, image 2 of 3 How to Use a Needle Threader: step 5, image 3 of 3
    • Pull the tail end of the thread until both threads are equal in length.
    • Holding both lengths of thread together, tie a knot near the end and pull it tight.
    • This will trap the needle in the loop of thread and allow you to sew with doubled thread. If you prefer to sew with a single thread, tie a knot in only one of the threads, not both.
    Ask FixBot
Finish Line
78 other people completed this guide.
Brittany McCrigler
90,987 Reputation
142 Guides authored
20 Guide Comments
thank you for this
it helped me with
sewing project
Swathika E - Reply Share
For years I have been doing this the hard way. I had no idea what the threader was. I have thrown so many away not knowing what they were. Thank you so much. You've made what i enjoy doing (sewing projects), even more enjoyable.
Shannon B, 01/06/2016
Shannon Beecham - Reply Share
Though I had a needle threader but didn't know how to use it ?
Your guidelines really helped me. Thanks a lot.
vickysos - Reply Share
Thank you. My automatic needle threader on sewing machine is off track and I'm not in the mood to locate online how to fix/correct it today. I had plenty of handheld and long neck serger needle threaders in my stash and couldn't figure out how to thread my needle on sewing machine with the long neck threader, but you helped me with that, thanks.
Bonita W - Reply Share
Thank you you are a Life saver!!!!
ciaaratpaen - Reply Share
Past 24 Hours: 97
Past 7 Days: 641
Past 30 Days: 3,133
All Time: 620,310
