Introduction
Do you have a flat tire, but don't have the time nor the strength to fill up your tires with a standard pump? Using a CO2 Cartridge is a quick and easy way to re-inflate your tires without much work compared to pumping tires full of air.
Figure out which tire is flat. In this case, the rear wheel is flat.
To easily remove the rear wheel, flip the bike upside down so that it's sitting on the handle bars and seat.
Disengage the quick-release lever to loosen the wheel.
Turn the quick-release lever a few times while you hold the cap on the opposite side of the wheel.
If the spring comes out, place the spring back on the bar and tighten the cap or lever.
Pull the wheel out.
Pull the rear shifter into a straight line so the wheel will be able to slide out smoothly.
Pull out the wheel with one hand while you hold the rear shifter.
Now that the rear wheel is off the bike, use the tire lever to get under the tire.
Once the tire lever is under the tire, bring it around the rim of the wheel slowly sliding the tire off wheel.
Place the inner tube back inside the tire.
Using the tire lever, pry the tire back onto the wheel.
Now that the tire is back on the wheel, screw the adapter onto the CO2 cartridge and place it on the valve.
Fit the wheel back onto the bike.
Pull the rear shifter into a straight line and place the gears underneath the chain to slide into place.
Tighten the quick-release lever and close it.
Twist the lever as you hold the cap on the opposite side as tight as possible.
Re-engage the brakes.
Turn the grey lever downwards on the brake, such as in step 2.
Pedal a little while the bike is lifted slightly off the ground to move the chain back into place.
