How to Unclog a Sink Using a Wet Vacuum
  1. How to Unclog a Sink Using a Wet Vacuum, How to Unclog a Sink Using a Wet Vacuum: step 1, image 1 of 1
    • Before starting, make sure your sink is empty.
    • Clear out the sink using a cup or sponge to remove any standing water for better suction.
  2. How to Unclog a Sink Using a Wet Vacuum: step 2, image 1 of 3 How to Unclog a Sink Using a Wet Vacuum: step 2, image 2 of 3 How to Unclog a Sink Using a Wet Vacuum: step 2, image 3 of 3
    • If your stopper is attached to the p-trap, removing it may cause water to leak. Be ready to duct tape it or have a towel or small bucket to catch the leak.
    • If your sink has a stopper plug, take it out.
    • This will give direct access to the clogged drain and improve suction.
    • Most sinks have detached stopper plugs. However, some sink stoppers are connected to the p-trap, so check which type you have and adjust accordingly.
  3. How to Unclog a Sink Using a Wet Vacuum: step 3, image 1 of 2 How to Unclog a Sink Using a Wet Vacuum: step 3, image 2 of 2
    • If your sink has an overflow hole, cover it with duct tape or a towel to seal it.
    • This helps maintain suction and prevents water from leaking through it.
  4. How to Unclog a Sink Using a Wet Vacuum: step 4, image 1 of 3 How to Unclog a Sink Using a Wet Vacuum: step 4, image 2 of 3 How to Unclog a Sink Using a Wet Vacuum: step 4, image 3 of 3
    • Ensure that your vacuum can suck up water, using a regular vacuum could cause damage to the vacuum.
    • Before setting up, open your wet vacuum so it’s ready for use.
  5. How to Unclog a Sink Using a Wet Vacuum: step 5, image 1 of 3 How to Unclog a Sink Using a Wet Vacuum: step 5, image 2 of 3 How to Unclog a Sink Using a Wet Vacuum: step 5, image 3 of 3
    • Check the settings on your vacuum to see if your filter is good for wet or dry use.
    • Remove the filter to avoid potential damage.
    • As a precaution, it's recommended to remove the filter even if it's designed for wet use to prevent potential damage over time.
  6. How to Unclog a Sink Using a Wet Vacuum: step 6, image 1 of 2 How to Unclog a Sink Using a Wet Vacuum: step 6, image 2 of 2
    • Position the vacuum hose directly over the drain.
    • Press the hose firmly against the drain.
    • If needed, add an inch of water to the sink before attaching the hose, this can help improve suction.
  7. How to Unclog a Sink Using a Wet Vacuum: step 7, image 1 of 3 How to Unclog a Sink Using a Wet Vacuum: step 7, image 2 of 3 How to Unclog a Sink Using a Wet Vacuum: step 7, image 3 of 3
    • Switch the vacuum to wet mode and turn it on.
    • Hold the hose over the drain for about two minutes to pull up the clog.
  8. How to Unclog a Sink Using a Wet Vacuum: step 8, image 1 of 2 How to Unclog a Sink Using a Wet Vacuum: step 8, image 2 of 2
    • The vacuum tank may fill up quickly, so be prepared to empty it once or twice during the process.
    • Check the vacuum hose for debris every few minutes.
    • If hair or gunk comes up, remove it by hand or with needle-nose pliers before continuing.
  9. How to Unclog a Sink Using a Wet Vacuum: step 9, image 1 of 2 How to Unclog a Sink Using a Wet Vacuum: step 9, image 2 of 2
    • Remove the hose from the sink.
    • Run water to see if the clog is cleared. If water still drains slowly, repeat the process or consider seeking professional assistance.
Finish Line
3 other people completed this guide.
Monica Collazo-Cofino
214 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 68
All Time: 419
