How to Troubleshoot a Shaking Samsung Front-Load Washing Machine
Video Guide
This guide was transcribed from a YouTube video.
    • Gather a drill or screwdriver with a Phillips bit for the covers and panels.
    • Have a 10 mm socket wrench ready for shipping bolts and some shock absorber hardware.
    • Have a 19 mm socket or impact gun ready if you plan to remove the rotor.
    • WARNING: The source video does not cover unplugging the washer or shutting off water, so follow your owner manual’s safety steps before opening panels.
    Ask FixBot
    • Place a level on the washer to check for sagging to any one side.
    • Check level at the front and at the rear of the washer.
    • Adjust the feet at each corner by screwing them in or out until the washer is level.
    • Make sure the floor is firm and hard, because a weak floor can cause shaking even if the washer is level.
    • Install anti-vibration pads or a mat if the floor is imperfect and you still have movement after leveling.
    • Reminder: If leveling fixes the shaking, stop here and run a spin to confirm the repair.
    Ask FixBot
    • Use a Phillips screwdriver to remove the two screws at the rear of the top cover.
    • Slide the top cover backward, and lift it off the washer.
    Ask FixBot
    • Inspect the two springs that hold the tub up from the top of the washer.
    • Look for springs that are warped, damaged, or off their mounting brackets on the tub or the chassis.
    • Caution: Support the tub with a box or another support before removing any spring, because the tub can fall down.
    • Use a trampoline spring tool to remove and install a spring if you need to replace one.
    Ask FixBot
    • Inspect the counterbalance weights on the front of the tub for cracks or damage.
    • Check the counterbalance under the front of the washer by tilting the washer on its side and looking for concrete dust or debris.
    • The source video says a closer inspection may require removing the front of the washer, but it does not show that procedure.
    Ask FixBot
    • Open the washer door and try to wiggle the inner metal tub independently of the outer plastic tub.
    • Treat any independent play or shifting as a strong sign the internal spider bracket has broken.
    • Spin the drum by hand and watch for a non-circular, warped, or wobbling pattern.
    • Check the drain trap, if your model has one, for small metal chunks that suggest internal metal parts are disintegrating.
    • A failed spider bracket is often a washer-killing failure, and repairs are commonly quoted around $400 to $600.
    • Reminder: Consider professional repair or replacement if this test fails, because the job can be costly and labor-intensive.
    Ask FixBot
    • Inspect the four shipping-bolt locations on the rear of the washer for bolts that were never removed after installation.
    • Remove any shipping bolt using a 10 mm socket wrench.
    • Shipping bolts lock the tub for transport, and leaving them installed transfers vibration into the chassis and can cause severe bouncing and knocking.
    Ask FixBot
    • Use a Phillips screwdriver to remove the four screws securing the rear metal panel.
    • Slide the rear panel down, and pull it away from the washer.
    Ask FixBot
    • Inspect the rear shock absorbers for separation, because some can come apart and sometimes pop back together.
    • Remove a shock absorber to test it if it looks damaged or if the washer still goes out of balance.
    • Use a 10 mm socket to remove the top and bottom hardware on this style of Samsung shock absorber.
    • Press the shock in by hand and confirm it is extremely difficult to compress.
    • Test each shock absorber individually, because a washer may have two, three, or four shocks depending on the model.
    • Reminder: Replace all the shocks as a set if any single shock absorber is weak or failed.
    Ask FixBot
    • Use a 19 mm socket or impact gun to remove the rotor bolt.
    • Caution: The bolt may be sealed with threadlocker, so hold the rotor or drum still while breaking the bolt loose.
    • Pull the rotor plate off evenly by pulling from both sides with equal spacing.
    • Caution: The magnets behind the rotor plate are delicate, and the rotor can be difficult to dislodge.
    Ask FixBot
    • Inspect the rotor magnets for cracks, missing pieces, or other damage that could cause improper rotation during spin.
    • Inspect the stator on the tub for similar damage.
    • Check for excessive play in the spider bracket and bearing area, because too much movement can let the tub assembly rub the front of the washer.
    • The source video identifies excessive play and rubbing as a root cause on the example washer and says the bracket and bearing system must be replaced.
    • The source video does not show a detailed bearing test procedure or any bearing replacement steps.
    Ask FixBot
    • Expect brief movement and some noise during early spin, because these washers may intentionally shift to rebalance clothes before full-speed spin.
    • Treat violent shaking, failure to spin out, or the wash time increasing as signs of an out-of-balance failure that still needs a mechanical cause found.
    • Consider a control board or PCB malfunction only after mechanical checks, because the source video describes it as difficult to diagnose.
    • Reminder: Seek a professional estimate if the spider bracket, bearings, or control board appears to be the cause, because these repairs can be expensive.
    Ask FixBot
Level the washer and complete a test cycle after the repair before returning it to regular use. Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
7,100 Reputation
224 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 45
Past 30 Days: 141
All Time: 782
