How to Tie a Tie: Half-Windsor
  1. How to Tie a Tie: Half-Windsor, Preparation: step 1, image 1 of 1
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Half-Windsor: step 2, image 1 of 1
    • Wrap the tie around the back of your neck with the narrow end on the left side of your body and the wide end on the right side.
    • The wide end of the tie will be your active end.
    • Note: The narrow end of the tie should be around the height of your belly button or a little higher. It may need to be adjusted for personal height.
  3. How to Tie a Tie: Half-Windsor, Tying: step 3, image 1 of 1
    • Take the active end and cross it over the narrow end, so it is pointing to the left.
    • Note: Be sure that the tie always lays flat so that there are no twists in the fabric.
  4. How to Tie a Tie: Half-Windsor: step 4, image 1 of 1
    • Cross the active end underneath the narrow end, so it is now pointing to the right.
  5. How to Tie a Tie: Half-Windsor: step 5, image 1 of 1
    • Lift the active end up over the right side of the neck loop, so it is pointing up.
  6. How to Tie a Tie: Half-Windsor: step 6, image 1 of 1
    • Pull the active end down through the loop around your neck so that it is pointing down and to the left.
  7. How to Tie a Tie: Half-Windsor: step 7, image 1 of 1
    • Cross it over the top of the knot to the right, so that it is now pointing to the right.
    • Note: leave this wrap a little loose, as it will be used in step 9.
  8. How to Tie a Tie: Half-Windsor: step 8, image 1 of 1
    • Pull the active end up through the loop around your neck, so that it is pointing straight up.
  9. How to Tie a Tie: Half-Windsor: step 9, image 1 of 2 How to Tie a Tie: Half-Windsor: step 9, image 2 of 2
    • Pull the active end down through the wrap you created in step 7 (see second picture).
  10. How to Tie a Tie: Half-Windsor, Finishing: step 10, image 1 of 1
    • Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
  11. How to Tie a Tie: Half-Windsor: step 11, image 1 of 1
    • Tighten the neck loop by pulling down on the narrow end of the tie and sliding the knot up toward your neck.
  12. How to Tie a Tie: Half-Windsor: step 12, image 1 of 1
    • Tuck the narrow end of the tie through the keeper loop.
    • Note: if the narrow end is too long, a simple solution lies in tucking the narrow end between two buttons of your shirt.
    • Fold your collar down when the knot is finished.
Congratulations! You've successful tied the Half-Windsor knot!
4 other people completed this guide.
Electric Warthogs
776 Reputation
3 Guides authored
The Electric Warthogs Member of The Electric Warthogs
Community
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 18
All Time: 946
