This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
How to Test a Capacitor with a Multimeter
      • Digital multimeter with capacitance and resistance modes
      • Insulated test leads or alligator clips
      • Discharge resistor (15 kΩ–50 kΩ, appropriate wattage)
      Ask FixBot
      • Capacitors can retain electrical charge even after power is disconnected.
      • Always discharge a capacitor before handling or testing it.
      • Failure to do so can result in electric shock, damage to the multimeter, or injury.
      • Never short a capacitor directly with a screwdriver, as this may cause sparks, arcing, or component damage.
      Ask FixBot
      • Use a resistor connected across the capacitor terminals to discharge stored energy safely. Hold the resistor in place for several seconds to ensure the voltage drops to a safe level.
      • Confirm with the multimeter (DC voltage mode) that the residual voltage is close to zero before proceeding.
      Ask FixBot
      • For accurate measurements, remove the capacitor from the circuit board or disconnect at least one of its leads.
      • Testing a capacitor in-circuit can lead to incorrect readings due to parallel components such as resistors or inductors.
      Ask FixBot
    1. How to Test a Capacitor with a Multimeter, Measure Capacitance with a Multimeter: step 5, image 1 of 1
      • Most modern digital multimeters include a dedicated capacitance mode, typically marked with a capacitor symbol. Set the multimeter to capacitance mode.
      • Connect the red probe to the positive terminal and the black probe to the negative terminal (for polarized capacitors). Wait for the reading to stabilize on the display.
      • Compare the measured value to the capacitance rating printed on the capacitor body. In general, a capacitor is considered acceptable if the measured value is within ±10–20% of its rated capacitance. Values significantly lower than the rating usually indicate degradation or failure.
      Ask FixBot
    2. How to Test a Capacitor with a Multimeter, Test Using Resistance (Ohm) Mode: step 6, image 1 of 1
      • If your multimeter doesn't support capacitance measurement, resistance mode can still provide useful information. You can set the multimeter to a medium resistance range (e.g., 1 kΩ or 10 kΩ). Then connect the probes to the two terminals of the capacitor and observe the changes on the display.
      • A normal capacitor will initially show a low resistance value, which then gradually increases to a very high resistance value as it charges. If the reading remains close to zero, the capacitor is short-circuited. If the reading always shows infinity and doesn't change, the capacitor may be open-circuited and damaged.
      Ask FixBot
      • Another simple method is to check if the capacitor can retain its charge. We briefly charge the capacitor using a low-voltage DC power supply below its rated voltage. After disconnecting the power, set the multimeter to DC voltage mode and measure the voltage across the capacitor.
      • If the capacitor retains a voltage close to the applied voltage (briefly), it is likely working correctly. If the voltage immediately drops to zero, the capacitor may be faulty.
      Ask FixBot
A multimeter with capacitance mode provides the most direct and reliable results, while resistance and voltage-based methods can serve as practical alternatives. For a more detailed explanation of capacitor behavior, safety standards, and advanced testing methods, see this in-depth guide:
How to Test a Capacitor with a Multimeter – Detailed Guide
2 other people completed this guide.
Colin
389 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 30
Past 7 Days: 247
Past 30 Days: 879
All Time: 1,810
