15% Off Selected iFixit Tools — Limited Time
Sidekick II Thumbwheel Replacement
  1. Sidekick II Thumbwheel Replacement, Outer Casing: step 1, image 1 of 1
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
    Ask FixBot
  2. Sidekick II Thumbwheel Replacement: step 2, image 1 of 2 Sidekick II Thumbwheel Replacement: step 2, image 2 of 2
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
    Ask FixBot
  3. Sidekick II Thumbwheel Replacement: step 3, image 1 of 1
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
    Ask FixBot
  4. Sidekick II Thumbwheel Replacement: step 4, image 1 of 1
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
    Ask FixBot
  5. Sidekick II Thumbwheel Replacement: step 5, image 1 of 1
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
    Ask FixBot
  6. Sidekick II Thumbwheel Replacement, Thumbwheel: step 6, image 1 of 1
    • Remove 2 screws using the Torx 6 screwdriver.
    Ask FixBot
  7. Sidekick II Thumbwheel Replacement: step 7, image 1 of 1
    • The thumbwheel and casing will be loose, gently remove it.
    Ask FixBot
Finish Line
michael albaum
108 Reputation
6 Guides authored
Cal Poly, Team 3-19, Maness Winter 2010 Member of Cal Poly, Team 3-19, Maness Winter 2010
CPSU-MANESS-W10S3G19
4 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 37
All Time: 2,468
