Motorola California Mobile Phone Motherboard Replacement
    1. Motorola California Mobile Phone Motherboard Replacement, Motorola California Mobile Phone Teardown: step 1, image 1 of 1
      • Remove the battery by sliding it down the rails to which it is connected.
      Ask FixBot
    2. Motorola California Mobile Phone Motherboard Replacement: step 2, image 1 of 1
      • Find a flat head or Phillips head screwdriver.
      • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
      • Use the screwdriver to push the rods towards each other until they click out of their locked position.
      • Note: This may require a large amount of force.
      Ask FixBot
    3. Motorola California Mobile Phone Motherboard Replacement: step 3, image 1 of 1
      • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
      • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
      • Remove the key guard from the rear casing by taking it out of its position.
      Ask FixBot
    4. Motorola California Mobile Phone Motherboard Replacement: step 4, image 1 of 1
      • Locate and unplug the black component of the antenna from the motherboard.
      • Under the black component should be a blue component. Unscrew this component in order to free the antenna.
      Ask FixBot
    5. Motorola California Mobile Phone Motherboard Replacement: step 5, image 1 of 1
      • Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
      Ask FixBot
    6. Motorola California Mobile Phone Motherboard Replacement: step 6, image 1 of 1
      • Lift the motherboard out of its location in the front casing.
      • Do this slowly and gently so that none of the motherboard's components are damaged.
      Ask FixBot
    1. Motorola California Mobile Phone Motherboard Replacement, Motherboard: step 7, image 1 of 1
      • With your new motherboard, hold the LCD side of the motherboard face down. Align the four clips on the front casing with the four notches on the motherboard.
      • While doing so, insert the LCD into the compartment in the front casing.
      Ask FixBot
    2. Motorola California Mobile Phone Motherboard Replacement: step 8, image 1 of 1
      • Press firmly on the motherboard until it is snug inside the casing.
      Ask FixBot
2 other people completed this guide.
Andrew Lam
53 Reputation
4 Guides authored
Cal Poly, Team 9-46, Regan Spring 2012 Member of Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
5 Members
72 Guides authored
1 Guide Comment
Nice, thanks.
Daniel - Reply Share
Past 24 Hours: 1
Past 7 Days: 29
Past 30 Days: 65
All Time: 3,580
