How to Shorten the Drawstring on BJJ Gi Pants
  1. How to Shorten the Drawstring on BJJ Gi Pants, How to Shorten the Drawstring on BJJ Gi Pants: step 1, image 1 of 3 How to Shorten the Drawstring on BJJ Gi Pants, How to Shorten the Drawstring on BJJ Gi Pants: step 1, image 2 of 3 How to Shorten the Drawstring on BJJ Gi Pants, How to Shorten the Drawstring on BJJ Gi Pants: step 1, image 3 of 3
    • Put on your Gi pants and adjust the drawstring to the desired tightness.
    • Pull both ends of the drawstring in opposite directions so that they are in front of the pants. Ensure both ends are of nearly equal length, then tie a knot in the center.
    • Use a pen to mark the point where you want the drawstring to end on both sides.
    • Leave at least 2 inches from where the knot ends to ensure you have enough length for tying.
  2. How to Shorten the Drawstring on BJJ Gi Pants: step 2, image 1 of 3 How to Shorten the Drawstring on BJJ Gi Pants: step 2, image 2 of 3 How to Shorten the Drawstring on BJJ Gi Pants: step 2, image 3 of 3
    • Pull one end of the drawstring while holding the waistline of the pants firmly.
    • Continue pulling until the drawstring is entirely out of the waistband.
  3. How to Shorten the Drawstring on BJJ Gi Pants: step 3, image 1 of 3 How to Shorten the Drawstring on BJJ Gi Pants: step 3, image 2 of 3 How to Shorten the Drawstring on BJJ Gi Pants: step 3, image 3 of 3
    • Hold the drawstring steady at the marked points.
    • Use sharp scissors to cut the drawstring at the marked ends, one side at a time.
    • The drawstring material is tough and durable; it's better to cut one end at a time for better control and precision.
  4. How to Shorten the Drawstring on BJJ Gi Pants: step 4, image 1 of 3 How to Shorten the Drawstring on BJJ Gi Pants: step 4, image 2 of 3 How to Shorten the Drawstring on BJJ Gi Pants: step 4, image 3 of 3
    • Hold the lighter close to the end of the drawstring until it starts to melt slightly.
    • Once the end of the drawstring is melted, let it cool down and harden. This will seal the ends and prevent fraying.
    • Repeat the process for the other end of the drawstring.
    • Be very careful when using the lighter to avoid burns or excessive melting. To achieve sealing without burning, only hold the flame to the drawstring for a short time.
  5. How to Shorten the Drawstring on BJJ Gi Pants: step 5, image 1 of 2 How to Shorten the Drawstring on BJJ Gi Pants: step 5, image 2 of 2
    • Attach a safety pin to one end of the drawstring.
  6. How to Shorten the Drawstring on BJJ Gi Pants: step 6, image 1 of 3 How to Shorten the Drawstring on BJJ Gi Pants: step 6, image 2 of 3 How to Shorten the Drawstring on BJJ Gi Pants: step 6, image 3 of 3
    • Insert the end of the drawstring with the safety pin into the waistband of the pants.
    • Guide the safety pin through the waistband, working it through the front and back of the pants until it comes out on the other side.
    • Thread the drawstring evenly to avoid bunching and ensure it is distributed evenly throughout the waistband.
  7. How to Shorten the Drawstring on BJJ Gi Pants: step 7, image 1 of 3 How to Shorten the Drawstring on BJJ Gi Pants: step 7, image 2 of 3 How to Shorten the Drawstring on BJJ Gi Pants: step 7, image 3 of 3
    • Pull the drawstrings on both sides to ensure they are of equal length, as shown in the photo.
    • Tie a knot in the center of the pants, adjusting it to a comfortable tightness.
    • Check if the desired length for training is achieved. If not, adjust as necessary.
Ensure that the specified length is reached. If not, repeat the process.
Seyedehzahra Ghavamitoranji
145 Reputation
1 Guide authored
1 Guide Comment
Thanks for including the safety pin trick to put the draw string back into the waistband. I had no idea how to approach that problem until now! The photos are great too.
vvaylon_k - Reply Share
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 44
All Time: 550
