How to Shorten Pant Legs With a Sewing Machine
  1. How to Shorten Pant Legs With a Sewing Machine, How to Shorten Pant Legs With a Sewing Machine: step 1, image 1 of 1
    • Flip the pairs of pants inside out.
    • The seam lines should be visible, markings the inside of the pants will allow for an easier clean up.
    • Place your pants on a flat surface and flatten the pant leg.
  2. How to Shorten Pant Legs With a Sewing Machine: step 2, image 1 of 1
    • Measure the width of the pant leg using a ruler or measuring tape.
    • Mark your fitting size on the pants using tailoring chalk.
  3. How to Shorten Pant Legs With a Sewing Machine: step 3, image 1 of 2 How to Shorten Pant Legs With a Sewing Machine: step 3, image 2 of 2
    • Use a seam ripper to unseam the hem of your pants a little bit past your fitting line.
    • Make another marking from your fitting line, leaving half an inch of space in between the two.
    • In this case, the top line is our fit line and the bottom line is our cut line.
  4. How to Shorten Pant Legs With a Sewing Machine: step 4, image 1 of 3 How to Shorten Pant Legs With a Sewing Machine: step 4, image 2 of 3 How to Shorten Pant Legs With a Sewing Machine: step 4, image 3 of 3
    • Use a comma ruler to extend both of your markings up the length of the pants.
    • Cut along the lower line.
  5. How to Shorten Pant Legs With a Sewing Machine: step 5, image 1 of 3 How to Shorten Pant Legs With a Sewing Machine: step 5, image 2 of 3 How to Shorten Pant Legs With a Sewing Machine: step 5, image 3 of 3
    • Sew your new seam along thefitting line.
    • As you get closer to the original seam, blend your new seam into the original.
    • Sewing machines can easily cause injuries, use caution when operating and go slow.
  6. How to Shorten Pant Legs With a Sewing Machine: step 6, image 1 of 2 How to Shorten Pant Legs With a Sewing Machine: step 6, image 2 of 2
    • Once you've laid your new seam, refold the hem and place a seam to hold it.
    • Make sure to go slow, the thickness of the cloth can make this difficult.
    • Repeat the procedure for the other pant leg.
Finish Line
Divyansh Bhatti
134 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 30
All Time: 305
