How to Sharpen a Dull Chisel
    1. How to Sharpen a Dull Chisel, How to Sharpen a Dull Chisel: step 1, image 1 of 1
      • Use water or a mild cleaning solution with a rag or sponge to remove any grime or dirt from the chisel.
      • This helps expose any rust or damage and prevents debris from interfering with sharpening later.
      Ask FixBot
    2. How to Sharpen a Dull Chisel: step 2, image 1 of 1
      • Next apply WD40 lubricant around any rusted areas before moving on to the next step.
      • Scraping dry rust can damage the metal and make the process unnecessarily difficult.
      Ask FixBot
    3. How to Sharpen a Dull Chisel: step 3, image 1 of 1
      • Use a brass wire brush to scrub the rusted areas.
      • Focus especially on the blade and any areas that will contact the sharpening stone.
      • Use caution with the wire brush, as its sharp bristles can cause injury.
      Ask FixBot
    4. How to Sharpen a Dull Chisel: step 4, image 1 of 1
      • Use a clean rag to remove any leftover WD-40 or rust residue.
      • This is important — if oil stays on the blade, it can make your sharpening stone less effective by repelling water.
      Ask FixBot
    5. How to Sharpen a Dull Chisel: step 5, image 1 of 2 How to Sharpen a Dull Chisel: step 5, image 2 of 2
      • Soak the wet sharpening stone with water for a couple of minutes and place it on a flat surface.
      • Hold the chisel at a 20-degree angle and push it forward against the stone to grind the edge. After each stroke, lift the chisel and return it to the starting position.
      • Repeat this motion on both sides of the stone until the chisel reaches your desired sharpness.
      • Water acts as a lubricant, helping to carry away metal particles and prevent clogging during sharpening.
      Ask FixBot
    6. How to Sharpen a Dull Chisel: step 6, image 1 of 2 How to Sharpen a Dull Chisel: step 6, image 2 of 2
      • With a rag, carefully wipe of any debris and metal shaving possible left on the chisel.
      • Apply a small amount of WD-40 to protect the metal from rust.
      • Keep in mind that this is only a temporary measure.
      • Use caution—this blade is now significantly sharper.
      Ask FixBot
After you follow all these steps, you should have a nice, clean chisel
2 other people completed this guide.
Christine Vu
151 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 97
All Time: 511
