Right-Side Cover Removal
View statistics:
Past 24 Hours:
2
Past 7 Days:
4
Past 30 Days:
25
All Time:
121
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Follow this guide to remove the right-side cover of a Mi-T-M heater model MH-0190-0M10.
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
    1. Right-Side Cover Removal, Safety precautions: step 1, image 1 of 2 Right-Side Cover Removal, Safety precautions: step 1, image 2 of 2
      • Power off the machine at least one hour prior to starting repairs. Ensure the machine is completely cool to the touch.
      • Flip the power switch into the OFF position.
      • Unplug any extension cords from the included power cord.
      Ask FixBot
    1. Right-Side Cover Removal, Remove the upper shell: step 2, image 1 of 2 Right-Side Cover Removal, Remove the upper shell: step 2, image 2 of 2
      • Use a 5/16 inch socket or Phillips screwdriver to remove the eight screws securing the upper shell, four on each side.
      Ask FixBot
    2. Right-Side Cover Removal: step 3, image 1 of 2 Right-Side Cover Removal: step 3, image 2 of 2
      • Lift the upper shell straight up off of the machine to remove it.
      Ask FixBot
    1. Right-Side Cover Removal, Remove the right-side cover: step 4, image 1 of 1
      • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the right-side cover.
      Ask FixBot
    2. Right-Side Cover Removal: step 5, image 1 of 3 Right-Side Cover Removal: step 5, image 2 of 3 Right-Side Cover Removal: step 5, image 3 of 3
      • Tilt the right-side cover down to access the PCB board.
      • Do not fully remove the right-side cover, it is still attached via the on/off switch.
      • During reassembly, ensure the display window is aligned with the LCD display before you press the cover into place.
      Ask FixBot
    3. Right-Side Cover Removal: step 6, image 1 of 3 Right-Side Cover Removal: step 6, image 2 of 3 Right-Side Cover Removal: step 6, image 3 of 3
      • There are two wires connecting the power switch to the main PCB assembly.
      • Use needle nose pliers to remove the wire with the blue connector.
      • Remove the wire with the clear connector.
      • Remove the right-side cover.
      • During reassembly, install the power switch wires back in their original locations with the blue wire above the clear wire.
      Ask FixBot
Sam Omiotek
101,271 Reputation
289 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 25
All Time: 121
