How to Rotate Your Tires
  1. How to Rotate Your Tires, Using a Floor Jack: step 1, image 1 of 2 How to Rotate Your Tires, Using a Floor Jack: step 1, image 2 of 2
    • Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
    • The crossmember is the long metal support beam that runs underneath from the front fender to the rear fender on both sides of the car.
    • The saddle is the round metal part of the jack that moves upward as you pump the jack up.
  2. How to Rotate Your Tires, Using floor jack to lift car.: step 2, image 1 of 1
    • Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
  3. How to Rotate Your Tires: step 3, image 1 of 1
    • Place the jack stand under the jack mounting point.
    • The jack mounting point is a metallic protrusion beneath each of the car doors.
  4. How to Rotate Your Tires: step 4, image 1 of 1
    • Raise the jack stand until it contacts the jack mounting point.
    • In the event the floor jack fails, the jack stand is designed to prevent the car from falling.
  5. How to Rotate Your Tires, How to Rotate Your Tires: step 5, image 1 of 1
    • Once the car is raised, remove the lug nuts with the ratchet attached to a 3/4'' socket.
  6. How to Rotate Your Tires: step 6, image 1 of 3 How to Rotate Your Tires: step 6, image 2 of 3 How to Rotate Your Tires: step 6, image 3 of 3
    • Remove the tire off the wheel studs and place it aside.
    • The wheel studs are the metal bolts sticking out of the wheel hub in the center.
  7. How to Rotate Your Tires: step 7, image 1 of 1
    • On the same side of the vehicle, go to the rear tire.
    • Using a ratchet attached to a 3/4" socket, loosen wheel lug nuts. Do not remove them.
    • Loosening the lug nuts while the tire is on the ground prevents the tire from spinning.
  8. How to Rotate Your Tires: step 8, image 1 of 2 How to Rotate Your Tires: step 8, image 2 of 2
    • Place the floor jack under the frame in front of the rear tire.
    • Make sure that you are not pressed against the plastic and you are directly on the metal frame of the vehicle.
    • Raise the jack until the tire is off the ground.
  9. How to Rotate Your Tires: step 9, image 1 of 1
    • Remove the lug nuts by loosening them with your hands.
  10. How to Rotate Your Tires: step 10, image 1 of 1
    • Remove the rear tire. Roll and place the tire onto the wheel studs on the front wheel.
    • Tighten the lug nuts using your hand until they are tight.
    • Roll the previous front tire to the rear and repeat the tightening process
  11. How to Rotate Your Tires: step 11, image 1 of 1
    • Using a torque wrench, tighten the lug nuts on each wheel to 80 ft-lbs.
    • If a torque wrench is not available, use the ratchet attached to the 3/4'' socket to hand-tighten the lug nuts until very tight.
  12. How to Rotate Your Tires: step 12, image 1 of 1
    • Using an air compressor and the air pressure gauge, fill the front and rear tires to appropriate amount.
Shaun MacDonald
2,558 Reputation
8 Guides authored
Cal Poly, Team 24-27, Regan Fall 2012 Member of Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Members
22 Guides authored
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 23
All Time: 6,659
