How to Resize Baggy Overalls
    1. How to Resize Baggy Overalls, How to Resize Baggy Overalls: step 1, image 1 of 3 How to Resize Baggy Overalls, How to Resize Baggy Overalls: step 1, image 2 of 3 How to Resize Baggy Overalls, How to Resize Baggy Overalls: step 1, image 3 of 3
      • Try on the overalls.
      • Take your ruler and measure from the bottom of the crotch up to the desired crotch point.
      • Take note of your measurements.
      Ask FixBot
    2. How to Resize Baggy Overalls: step 2, image 1 of 3 How to Resize Baggy Overalls: step 2, image 2 of 3 How to Resize Baggy Overalls: step 2, image 3 of 3
      • Flip the overalls inside out and lay them flat.
      • Use the ruler to place the recorded intake length measured in Step 1.
      • Mark the top of this measurement on the center seam of the overalls.
      Ask FixBot
    3. How to Resize Baggy Overalls: step 3, image 1 of 3 How to Resize Baggy Overalls: step 3, image 2 of 3 How to Resize Baggy Overalls: step 3, image 3 of 3
      • Using your fabric chalk, draw an angled line from the top of your crotch point to blend seamlessly with the bottom of your inseam.
      • Measure the line just marked.
      • Repeat measurements on the other side.
      Ask FixBot
    4. How to Resize Baggy Overalls: step 4, image 1 of 3 How to Resize Baggy Overalls: step 4, image 2 of 3 How to Resize Baggy Overalls: step 4, image 3 of 3
      • Take your pins and pin them downwards along both lines.
      • Make sure to pin on both sides of the fabric and leave about 3" of spacing between each pin.
      • Be careful not to prod your fingers when pinning the fabric.
      Ask FixBot
    5. How to Resize Baggy Overalls: step 5, image 1 of 2 How to Resize Baggy Overalls: step 5, image 2 of 2
      • Try on the pinned overalls to ensure a comfortable fit.
      • If the measurements still need adjustment, head to Step 6.
      • If the measurements are perfect, head to Step 7.
      • Be careful when trying on the overalls. Wear a pair of long pants under to protect from being poked.
      Ask FixBot
    6. How to Resize Baggy Overalls: step 6, image 1 of 3 How to Resize Baggy Overalls: step 6, image 2 of 3 How to Resize Baggy Overalls: step 6, image 3 of 3
      • Lay your overalls back on a flat surface.
      • Take your fabric chalk and redraw your new measurements
      • Re-pin your new measurements.
      Ask FixBot
    7. How to Resize Baggy Overalls: step 7, image 1 of 3 How to Resize Baggy Overalls: step 7, image 2 of 3 How to Resize Baggy Overalls: step 7, image 3 of 3
      • Sewing machine set up will vary with each machine. Refer to the article in the introduction on How to Use a Sewing Machine as needed.
      • Bring your overalls under the sewing needle and line the needle to the top of the crotch marker.
      • Gently press the foot pedal below to slowly start moving your fabric along your chalk line.
      • When you reach a pin, pause machine before removing.
      • Run the machine through the end of your marker point.
      • Cut the excess thread after the pass.
      Ask FixBot
    8. How to Resize Baggy Overalls: step 8, image 1 of 3 How to Resize Baggy Overalls: step 8, image 2 of 3 How to Resize Baggy Overalls: step 8, image 3 of 3
      • Cut the fabric along the sewn seam.
      • Leave half an inch of fabric from your seam to prevent loosening.
      Ask FixBot
    9. How to Resize Baggy Overalls: step 9, image 1 of 3 How to Resize Baggy Overalls: step 9, image 2 of 3 How to Resize Baggy Overalls: step 9, image 3 of 3
      • Flip your overalls inside out.
      • Try them on and you're done!
      Ask FixBot
Emily Le
169 Reputation
1 Guide authored
UC Davis, Team 2-1, Andersen Winter 2024 Member of UC Davis, Team 2-1, Andersen Winter 2024
UCD-ANDERSEN-W24S2G1
3 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 70
Past 30 Days: 322
All Time: 4,289
