How to Replace the Strings on a Zheng
  1. How to Replace the Strings on a Zheng, Strings: step 1, image 1 of 1
    • Twist the tuning pin to release tension in the string.
    • The string may snap and cause injury if the tension hasn't been released.
    • Use the diagonal plier to cut the old strings.
    • Remove the zheng bridges from the board.
  2. How to Replace the Strings on a Zheng: step 2, image 1 of 3 How to Replace the Strings on a Zheng: step 2, image 2 of 3 How to Replace the Strings on a Zheng: step 2, image 3 of 3
    • Using the zheng wrench, loosen the tuning pins by counterclockwise direction.
    • Turn the pin until there are three loops of the string wound remaining around the pin.
    • Remove the string from the pin.
    • Remove the string at the end side as well.
  3. How to Replace the Strings on a Zheng: step 3, image 1 of 1
    • Use a dry cloth to clean the dust under the position of the old string.
  4. How to Replace the Strings on a Zheng: step 4, image 1 of 3 How to Replace the Strings on a Zheng: step 4, image 2 of 3 How to Replace the Strings on a Zheng: step 4, image 3 of 3
    • Untie the new string and hold the tail of the string.
    • Flip the zheng stand. Insert the new string into the corresponding hole and pull all the way until the metal stopper attaches in the hole.
    • Repeat to insert all new strings.
  5. How to Replace the Strings on a Zheng: step 5, image 1 of 2 How to Replace the Strings on a Zheng: step 5, image 2 of 2
    • Flip the zheng to the back of the head side and insert the other side of the string into the corresponding hole of zheng and the pin.
    • Coil the string tightly around the pin, use the zheng wrench to tight the pin.
  6. How to Replace the Strings on a Zheng: step 6, image 1 of 2 How to Replace the Strings on a Zheng: step 6, image 2 of 2
    • Put the zheng bridges underneath the strings in the corresponding order by using the zheng bridge position schematic diagram to detect the zheng bridge position.
    • The zheng bridge position schematic diagram (picture 2) is available to purchase on Amazon.
  7. How to Replace the Strings on a Zheng: step 7, image 1 of 1
    • Use a tuner to tune the strings correctly.
Finish Line
Beiqi Cai
151 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 14
All Time: 172
