How to Replace the Rear Wheel of a Segway Ninebot ES4
  1. How to Replace the Rear Wheel of a Segway Ninebot ES4, Segway Ninebot ES4 Rear Wheel: step 1, image 1 of 3 How to Replace the Rear Wheel of a Segway Ninebot ES4, Segway Ninebot ES4 Rear Wheel: step 1, image 2 of 3 How to Replace the Rear Wheel of a Segway Ninebot ES4, Segway Ninebot ES4 Rear Wheel: step 1, image 3 of 3
    • Place the scooter on its side and locate the two access screw holes.
    • Use a flathead screwdriver to remove the protective inserts.
  2. How to Replace the Rear Wheel of a Segway Ninebot ES4: step 2, image 1 of 2 How to Replace the Rear Wheel of a Segway Ninebot ES4: step 2, image 2 of 2
    • Use a 3/32" hex key wrench to remove the screws that are securing the rear casing.
  3. How to Replace the Rear Wheel of a Segway Ninebot ES4: step 3, image 1 of 2 How to Replace the Rear Wheel of a Segway Ninebot ES4: step 3, image 2 of 2
    • Remove the rear casing and disconnect the rear light power cable.
    • Reposition the scooter to allow access to the opposite side. Then, repeat steps 1-3 to expose both sides of the rear wheel.
  4. How to Replace the Rear Wheel of a Segway Ninebot ES4: step 4, image 1 of 2 How to Replace the Rear Wheel of a Segway Ninebot ES4: step 4, image 2 of 2
    • Use a T25 star screwdriver on each side to remove the screw securing the axle.
  5. How to Replace the Rear Wheel of a Segway Ninebot ES4: step 5, image 1 of 2 How to Replace the Rear Wheel of a Segway Ninebot ES4: step 5, image 2 of 2
    • Insert a screwdriver into the hole where the screw was removed.
    • Use it to push the axle out from the opposite side.
  6. How to Replace the Rear Wheel of a Segway Ninebot ES4: step 6, image 1 of 3 How to Replace the Rear Wheel of a Segway Ninebot ES4: step 6, image 2 of 3 How to Replace the Rear Wheel of a Segway Ninebot ES4: step 6, image 3 of 3
    • Locate the rear wheel replacement.
    • Insert the axle into the scooter's rear axle housing.
    • Once the axle is in place, position the replacement wheel onto the axle while it is inside the scooter.
    • Ensure that the arrow-like grip pattern on the wheel points toward the front of the scooter.
  7. How to Replace the Rear Wheel of a Segway Ninebot ES4: step 7, image 1 of 2 How to Replace the Rear Wheel of a Segway Ninebot ES4: step 7, image 2 of 2
    • Place the star screw on the side opposite to where the axle was inserted.
    • Use a T25 star screwdriver on each side to tighten and secure the rear axle.
  8. How to Replace the Rear Wheel of a Segway Ninebot ES4: step 8, image 1 of 2 How to Replace the Rear Wheel of a Segway Ninebot ES4: step 8, image 2 of 2
    • Before reinstalling the rear casing, connect the rear light power cable.
    • Ensure you line up the connection points so the small protrusion pairs with the corresponding hole.
  9. How to Replace the Rear Wheel of a Segway Ninebot ES4: step 9, image 1 of 2 How to Replace the Rear Wheel of a Segway Ninebot ES4: step 9, image 2 of 2
    • After connecting the cable, reinstall the rear casing.
    • The cable should pass underneath the circled protrusion when installed.
  10. How to Replace the Rear Wheel of a Segway Ninebot ES4: step 10, image 1 of 2 How to Replace the Rear Wheel of a Segway Ninebot ES4: step 10, image 2 of 2
    • Use a 3/32" hex key wrench to install the screws that secure the rear casing.
  11. How to Replace the Rear Wheel of a Segway Ninebot ES4: step 11, image 1 of 2 How to Replace the Rear Wheel of a Segway Ninebot ES4: step 11, image 2 of 2
    • Place the protective inserts back inside the screw holes.
    • Reposition the scooter to allow access to the opposite side. Then, repeat steps 8-11.
With that, you've replaced the rear wheel of your Segway Ninebot ES4! Happy scootering!
Dylan Huang
194 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 28
All Time: 884
