Introduction
This guide will teach you how to fix the problem of an unusable output jack on your Sterling by Music Man Stingray bass guitar using a 3mm screwdriver, a soldering station, a flat surface, and a 1/4" Enclosed Mono Jack as a replacement.
There is a vast list of potential reasons for a bass guitar to need repairs. Standard wear and tear from use can cause some parts of your bass to stop working properly, and there is also a risk of causing further damage to your instrument on accident through dropping, bumping, or hitting it.
In this guide, we will walk you through the process of removing and replacing the damaged output jack in the safest and most eco-friendly way possible, reducing waste production and saving money in the process.
Â
âš WARNING: Soldering irons can reach very high temperatures. Use extreme caution to avoid fires and severe burns.
âš Caution: Remove the battery from the bass before coming into contact with wires to avoid shock.
Locate the battery box on the back of the bass, pulling down on the latch to open it.
Carefully detach the 9-volt battery from its connector, remove it from the slot, and close the hatch.
Prepare your soldering station by plugging it into a power source, pressing the power button, and setting the temperature to 700 degrees Fahrenheit or 375 degrees Celsius.
Wet your sponge so that you can clean the soldering iron periodically.
To prevent corrosion, melt some of the solder onto the iron to coat the tip.
Gently wipe off the tip of the iron on the steel wool, then on the damp sponge.
Congratulations! You've made your bass guitar sound as good as new!
