How to Replace the Mesh Screen Lid on a Front-Opening Terrarium
  1. How to Replace the Mesh Screen Lid on a Front-Opening Terrarium, Mesh Screen Lid: step 1, image 1 of 1
    • Spline roller:
    • We will use "Side A" (circled Red) to refer to the side with the outward-curved edge
    • We will use "Side B" (circled Orange) to refer to the side with a groove.
    • If you have an animal in your terrarium, carefully remove it and turn off any heat sources.
  2. How to Replace the Mesh Screen Lid on a Front-Opening Terrarium: step 2, image 1 of 1
    • Turn each semi-circle lock on the lid so the straight edge is parallel to the terrarium.
    • Lift the lid straight up and off of the terrarium.
  3. How to Replace the Mesh Screen Lid on a Front-Opening Terrarium: step 3, image 1 of 2 How to Replace the Mesh Screen Lid on a Front-Opening Terrarium: step 3, image 2 of 2
    • Pull out the spline from the frame of the lid.
    • Carefully remove the damaged mesh.
  4. How to Replace the Mesh Screen Lid on a Front-Opening Terrarium: step 4, image 1 of 1
    • On a flat surface, roll out your new mesh and place your terrarium lid on top of it.
    • Cut the mesh using the lid frame as an outline, leaving one inch of extra material on each side.
  5. How to Replace the Mesh Screen Lid on a Front-Opening Terrarium: step 5, image 1 of 2 How to Replace the Mesh Screen Lid on a Front-Opening Terrarium: step 5, image 2 of 2
    • Flip the mesh material and the lid frame so that the mesh is now on top of the frame.
    • Using Side A of the spline roller, press the mesh into the frame without the spline.
    • Line the frame with the spline and use Side B of the spline roller to press it in again.
  6. How to Replace the Mesh Screen Lid on a Front-Opening Terrarium: step 6, image 1 of 2 How to Replace the Mesh Screen Lid on a Front-Opening Terrarium: step 6, image 2 of 2
    • Use your scissors to cut off any extra mesh screen before replacing the lid on your enclosure.
Your lid is now ready for use. You can now place your pet back in the terrarium and cover the top with the repaired lid.
lizm2002
163 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 63
All Time: 399
