How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport
  1. How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport, How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport: step 1, image 1 of 1
    • First, check to see if your front-turn signal is not working properly or not bright enough.
  2. How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport: step 2, image 1 of 2 How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport: step 2, image 2 of 2
    • Turn on your car and turn your wheels so that you have access to the headlights and front-turn signal.
    • Make sure the car is in park and turned off before you begin making your repair.
  3. How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport: step 3, image 1 of 2 How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport: step 3, image 2 of 2
    • Use a flathead screwdriver and your hand to loosen the panel.
    • Pry the front bumper open away from the black panel.
  4. How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport: step 4, image 1 of 3 How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport: step 4, image 2 of 3 How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport: step 4, image 3 of 3
    • Look inside of the bumper and up towards where the headlights and front-turn signal are.
    • Locate the white bulb socket for the front-turn signal.
    • Reach inside and grab the white bulb socket
    • Twist counter-clockwise to remove the bulb and socket from their position.
  5. How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport: step 5, image 1 of 3 How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport: step 5, image 2 of 3 How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport: step 5, image 3 of 3
    • You should see the bulb being removed from its front-turn signal location.
  6. How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport: step 6, image 1 of 3 How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport: step 6, image 2 of 3 How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport: step 6, image 3 of 3
    • Pull the bulb socket and bulb out to an easy to handle area.
    • Remove the nonfunctioning bulb from the bulb socket.
    • Insert new bulb into the bulb socket and twist clockwise until it is tightly fastened.
  7. How to Replace the Front-Turn Signal Bulb in a 2011 Subaru Impreza Outback Sport: step 7, image 1 of 1
    • Now your front-turn signal should be working properly.
Austin Roberts
209 Reputation
1 Guide authored
Cal Poly, Team 14-1, Green Fall 2015 Member of Cal Poly, Team 14-1, Green Fall 2015
CPSU-GREEN-F15S14G1
4 Members
4 Guides authored
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 94
All Time: 16,900
