Canon EOS Rebel XSi Back Panel Replacement
    1. Canon EOS Rebel XSi Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Squeeze the eyepiece between your index finger and thumb and lift up and off.
      Ask FixBot
    2. Canon EOS Rebel XSi Back Panel Replacement: step 2, image 1 of 1
      • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
      Ask FixBot
    3. Canon EOS Rebel XSi Back Panel Replacement: step 3, image 1 of 1
      • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
      Ask FixBot
    4. Canon EOS Rebel XSi Back Panel Replacement: step 4, image 1 of 1
      • Remove grip by slowly peeling off.
      Ask FixBot
    5. Canon EOS Rebel XSi Back Panel Replacement: step 5, image 1 of 1
      • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
      Ask FixBot
    6. Canon EOS Rebel XSi Back Panel Replacement: step 6, image 1 of 1
      • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
      Ask FixBot
    7. Canon EOS Rebel XSi Back Panel Replacement: step 7, image 1 of 1
      • Remove the side panel by lifting off with fingers.
      Ask FixBot
    8. Canon EOS Rebel XSi Back Panel Replacement: step 8, image 1 of 1
      • Use hands to pry off the back panel.
      Ask FixBot
3 other people completed this guide.
Erik Mork
617 Reputation
5 Guides authored
Cal Poly, Team 22-10, Maness Winter 2017 Member of Cal Poly, Team 22-10, Maness Winter 2017
CPSU-MANESS-W17S22G10
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 1,795
