Asus X550ZA-SA100603E Hard Drive Replacement
  1. Asus X550ZA-SA100603E Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Remove all of the 10 bottom case screws.
    • Seven of them are 14 mm screws.
    • Three of them are 4 mm screws.
  2. Asus X550ZA-SA100603E Hard Drive Replacement: step 2, image 1 of 1
    • After the screws are removed, gently turn the computer to its upright position and open up the computer flap.
    • It is important to do this gently, as these pieces are loose.
  3. Asus X550ZA-SA100603E Hard Drive Replacement: step 3, image 1 of 1
    • Pry open a gap between the keyboard and the lower piece using a spudger.
    • This will uncover all of the internals in the laptop itself.
  4. Asus X550ZA-SA100603E Hard Drive Replacement: step 4, image 1 of 1
    • Slide the hard drive out of its position to allow room for the new one.
    • Make certain the area is clean and no debris got into the slot.
2 other people completed this guide.
Paul Flynn
16 Reputation
2 Guides authored
IUPUI, Team S5-G5, Wilson Spring 2019 Member of IUPUI, Team S5-G5, Wilson Spring 2019
IUPUI-WILSON-S19S5G5
3 Members
2 Guides authored
1 Guide Comment
There are steps omitted since the unit shown was already disassembled.
During Step 3: There will be four delicate ribbon cables, three connecting the Keyboard and one connecting the USB to the Motherboard that has adhesive and will be stuck to the drive, they all need to be carefully unplugged from the Motherboard.
Step 3.5: Four 4mm screws will be holding the drive tray in place and will have to be removed.
Alan Kay - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 21
All Time: 611
