How to Replace a Hoodie Drawstring
    1. How to Replace a Hoodie Drawstring, Hoodie Drawstring: step 1, image 1 of 2 How to Replace a Hoodie Drawstring, Hoodie Drawstring: step 1, image 2 of 2
      • If the broken or old drawstring is still in the hood, gently pull it through one of the hood holes.
      Ask FixBot
    2. How to Replace a Hoodie Drawstring: step 2, image 1 of 3 How to Replace a Hoodie Drawstring: step 2, image 2 of 3 How to Replace a Hoodie Drawstring: step 2, image 3 of 3
      • Wrap a small piece of tape tightly around each end.
      • This step is if you have frayed edges on your drawstring.
      Ask FixBot
    3. How to Replace a Hoodie Drawstring: step 3, image 1 of 2 How to Replace a Hoodie Drawstring: step 3, image 2 of 2
      • Open the safety pin and hook it through one end of the drawstring/shoelace.
      • If you put tape on frayed drawstring, stab the safety pin through the tape.
      • Be careful, your safety pin may be sharp!
      • Close the safety pin securely so it won't open when you put it in your hood.
      Ask FixBot
    4. How to Replace a Hoodie Drawstring: step 4, image 1 of 3 How to Replace a Hoodie Drawstring: step 4, image 2 of 3 How to Replace a Hoodie Drawstring: step 4, image 3 of 3
      • Insert the safety-pinned end into one drawstring hole.
      • Work it through the hood by bunching and sliding the hoodie fabric along the pin.
      • Keep feeding the pin until it exits the opposite hole.
      Ask FixBot
    5. How to Replace a Hoodie Drawstring: step 5, image 1 of 2 How to Replace a Hoodie Drawstring: step 5, image 2 of 2
      • Pull both ends of the drawstring until they're an even length.
      • Take out your safety pin.
      • Remove you tape (if any was used).
      • Make sure your string slides freely through the hood, and confirm it tightens as it's supposed to.
      Ask FixBot
    6. How to Replace a Hoodie Drawstring: step 6, image 1 of 3 How to Replace a Hoodie Drawstring: step 6, image 2 of 3 How to Replace a Hoodie Drawstring: step 6, image 3 of 3
      • Tie a small knot on each end to keep the string from slipping back in your hood!
      Ask FixBot
Replacing a hoodie drawstring is a quick, simple repair that saves your favorite hoodie from the donation pile. You can use this same method for sweatpants, jackets, or gym bags.
Mia Johnson
160 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 56
Past 30 Days: 208
All Time: 2,080
