How to Replace a Croc Ankle Strap Rivet
  1. How to Replace a Croc Ankle Strap Rivet, Croc Rivet: step 1, image 1 of 3 How to Replace a Croc Ankle Strap Rivet, Croc Rivet: step 1, image 2 of 3 How to Replace a Croc Ankle Strap Rivet, Croc Rivet: step 1, image 3 of 3
    • Use a flathead screwdriver to pry underneath the plastic rivet head.
    • Wiggle the plastic rivet until the head pops off.
  2. How to Replace a Croc Ankle Strap Rivet: step 2, image 1 of 3 How to Replace a Croc Ankle Strap Rivet: step 2, image 2 of 3 How to Replace a Croc Ankle Strap Rivet: step 2, image 3 of 3
    • Use your hands to remove the remaining part of the old rivet from inside the Croc.
  3. How to Replace a Croc Ankle Strap Rivet: step 3, image 1 of 3 How to Replace a Croc Ankle Strap Rivet: step 3, image 2 of 3 How to Replace a Croc Ankle Strap Rivet: step 3, image 3 of 3
    • Flip the Croc strap to the front of the sandal and apply a binder clip to hold the strap in place.
  4. How to Replace a Croc Ankle Strap Rivet: step 4, image 1 of 3 How to Replace a Croc Ankle Strap Rivet: step 4, image 2 of 3 How to Replace a Croc Ankle Strap Rivet: step 4, image 3 of 3
    • Insert the end of the new rivet through the hole from the inside of the Croc.
  5. How to Replace a Croc Ankle Strap Rivet: step 5, image 1 of 3 How to Replace a Croc Ankle Strap Rivet: step 5, image 2 of 3 How to Replace a Croc Ankle Strap Rivet: step 5, image 3 of 3
    • Place the head of the new rivet through the hole of the Croc strap.
    • Move the Croc strap so that the rivet head aligns with the opening of the rivet tail.
  6. How to Replace a Croc Ankle Strap Rivet: step 6, image 1 of 2 How to Replace a Croc Ankle Strap Rivet: step 6, image 2 of 2
    • Use a flathead screwdriver to turn the rivet head clockwise to tighten it.
  7. How to Replace a Croc Ankle Strap Rivet: step 7, image 1 of 3 How to Replace a Croc Ankle Strap Rivet: step 7, image 2 of 3 How to Replace a Croc Ankle Strap Rivet: step 7, image 3 of 3
    • Remove the binder clip.
  8. How to Replace a Croc Ankle Strap Rivet: step 8, image 1 of 3 How to Replace a Croc Ankle Strap Rivet: step 8, image 2 of 3 How to Replace a Croc Ankle Strap Rivet: step 8, image 3 of 3
    • To test for tightness, move the strap towards the back of the sandal.
    • If the strap bends instead of rotating freely, the screw is on too tight.
    • If necessary, to loosen the Croc strap, rotate the rivet head counterclockwise using a flathead screwdriver.
  9. How to Replace a Croc Ankle Strap Rivet: step 9, image 1 of 3 How to Replace a Croc Ankle Strap Rivet: step 9, image 2 of 3 How to Replace a Croc Ankle Strap Rivet: step 9, image 3 of 3
    • Check that the Croc strap can rotate freely.
Andy
178 Reputation
1 Guide authored
UC Davis, Team 2-1, Morris Spring 2023 Member of UC Davis, Team 2-1, Morris Spring 2023
UCD-MORRIS-S23S2G1
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 17
Past 7 Days: 115
Past 30 Days: 518
All Time: 25,122
