How to Replace a Broken Lanyard Clasp
  1. How to Replace a Broken Lanyard Clasp, Clasp: step 1, image 1 of 3 How to Replace a Broken Lanyard Clasp, Clasp: step 1, image 2 of 3 How to Replace a Broken Lanyard Clasp, Clasp: step 1, image 3 of 3
    • Use a seam ripper to carefully rip the seam holding the existing clasp.
  2. How to Replace a Broken Lanyard Clasp: step 2, image 1 of 3 How to Replace a Broken Lanyard Clasp: step 2, image 2 of 3 How to Replace a Broken Lanyard Clasp: step 2, image 3 of 3
    • Remove the existing clasp from the lanyard.
    • Use thread nippers to remove any remaining strings or fraying edges from the lanyard.
    • Make sure to trim as close to the base of the lanyard as possible without cutting into the main material.
  3. How to Replace a Broken Lanyard Clasp: step 3, image 1 of 3 How to Replace a Broken Lanyard Clasp: step 3, image 2 of 3 How to Replace a Broken Lanyard Clasp: step 3, image 3 of 3
    • Using a tape measure, measure out 24 inches (2 ft) of your choice of thread.
    • Snip the thread at the correct length with thread nippers.
    • Use as much thread as you think is necessary, keep in mind that a larger amount of thread can be tangled more easily.
  4. How to Replace a Broken Lanyard Clasp: step 4, image 1 of 2 How to Replace a Broken Lanyard Clasp: step 4, image 2 of 2
    • Feed one end of the cut thread through the eye of the needle.
    • Sometimes licking the end of the thread can make it easier to thread through the needle.
  5. How to Replace a Broken Lanyard Clasp: step 5, image 1 of 1
    • Pull the thread through the needle until the needle sits directly in the middle of the thread.
  6. How to Replace a Broken Lanyard Clasp: step 6, image 1 of 3 How to Replace a Broken Lanyard Clasp: step 6, image 2 of 3 How to Replace a Broken Lanyard Clasp: step 6, image 3 of 3
    • With the lower part of the thread, cross both sides over each other.
    • Tie the two sides together, making sure the knot stays towards the bottom of the thread.
  7. How to Replace a Broken Lanyard Clasp: step 7, image 1 of 3 How to Replace a Broken Lanyard Clasp: step 7, image 2 of 3 How to Replace a Broken Lanyard Clasp: step 7, image 3 of 3
    • Line up both sides of the lanyard.
    • Place the joined ends through the bottom of the new clasp.
    • Fold the lanyard over the bottom of the clasp.
    • Different lanyards may be configured differently. Follow the previous fold lines on your lanyard to best note how to rejoin the ends.
  8. How to Replace a Broken Lanyard Clasp: step 8, image 1 of 2 How to Replace a Broken Lanyard Clasp: step 8, image 2 of 2
    • Take the threaded needle and poke it through on one side of the lanyard.
    • Pull the needle and thread all the way through until the knot catches on the underside of the lanyard.
    • Make sure your needle goes through all the layers of the lanyard, paying particular attention to include the folded part.
  9. How to Replace a Broken Lanyard Clasp: step 9, image 1 of 3 How to Replace a Broken Lanyard Clasp: step 9, image 2 of 3 How to Replace a Broken Lanyard Clasp: step 9, image 3 of 3
    • Push the needle back down through all layers of the lanyard.
    • Pull all the way through until the thread is tight.
    • Continue moving back and forth across the lanyard until you reach the other end.
    • Keep the stitches as close together as possible for better stability.
  10. How to Replace a Broken Lanyard Clasp: step 10, image 1 of 1
    • Leave enough thread to comfortably tie a knot, so avoid cutting it too close to the lanyard.
    • Clip the thread in the middle of the remaining length.
    • Make sure you place your needle in a safe place now that is it free from the thread.
  11. How to Replace a Broken Lanyard Clasp: step 11, image 1 of 3 How to Replace a Broken Lanyard Clasp: step 11, image 2 of 3 How to Replace a Broken Lanyard Clasp: step 11, image 3 of 3
    • Cross the edges of the thread still attached to the lanyard.
    • Tie them together, making sure to tighten them down to the lanyard.
    • Repeat this a couple more times to ensure it won't come undone.
  12. How to Replace a Broken Lanyard Clasp: step 12, image 1 of 1
    • Clip the remaining thread.
    • The stitching should be secure so cut closely to the knot on the end.
  13. How to Replace a Broken Lanyard Clasp: step 13, image 1 of 1
    • All done! Enjoy your new lanyard clasp.
Finish Line
2 other people completed this guide.
Keely Hunt
259 Reputation
1 Guide authored
UC Davis, Team 2-6, Andersen Winter 2024 Member of UC Davis, Team 2-6, Andersen Winter 2024
UCD-ANDERSEN-W24S2G6
3 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 52
Past 30 Days: 218
All Time: 3,083
