How to Replace The Gasket On Your Refrigerator
    • Check if the refrigerator door gasket is removable from the omega groove.
    • Some newer refrigerators have a gasket embedded in the door requiring full door replacement.
    • Verify that your model supports gasket replacement before proceeding.
    • Unplug the refrigerator to disconnect electrical power.
    • Always ensure the appliance is powered off before starting repairs.
  1. How to Replace The Gasket On Your Refrigerator, Clean existing gasket: step 3, image 1 of 1
    • Clean the gasket thoroughly using a cleaning cloth and your chosen cleaning solution.
    • Use vinegar for a mild clean or bleach for heavy mold, neutralizing chlorine with vinegar or citric acid if needed.
    • For lighter cleaning, apply toothpaste to whiten the sealant.
  2. How to Replace The Gasket On Your Refrigerator, Inspect gasket condition: step 4, image 1 of 1
    • Examine the gasket for signs of hardening, tears, or holes.
    • A damaged gasket should be replaced rather than simply cleaned.
    • Decide if cleaning is sufficient or if a replacement is necessary.
    • Gently remove the gasket from the omega groove if it is not permanently embedded.
    • Handle the gasket carefully to avoid causing further damage.
    • Prepare the groove for the new or cleaned gasket.
  3. How to Replace The Gasket On Your Refrigerator, Install gasket ensuring a tight seal: step 6, image 1 of 1
    • Insert the new or cleaned gasket into the omega groove carefully.
    • Ensure the gasket fits evenly along the entire door edge.
    • Dampen the gasket slightly with water to help it slide into place.
    • A little moisture helps achieve a snug fit.
  4. How to Replace The Gasket On Your Refrigerator, Conclude repair and maintain seal: step 7, image 1 of 1
    • Confirm that the gasket is properly seated and forms a complete seal around the door.
    • Reconnect the power supply only after verifying that the repair is complete and safe.
    • Perform regular inspections and cleanings to extend the gasket’s lifespan.
    • A healthy gasket improves energy efficiency and appliance performance.
A properly installed and maintained gasket ensures optimal temperature control and energy efficiency in your refrigerator. Regular cleaning and inspection will extend the gasket's lifespan.
Ula Gantar
9,730 Reputation
46 Guides authored
ZEOS Slovenia Member of ZEOS Slovenia
Local Repair Groups
2 Members
54 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 41
All Time: 280
