How to Replace Pants Pockets
    1. How to Replace Pants Pockets, Pocket: step 1, image 1 of 3 How to Replace Pants Pockets, Pocket: step 1, image 2 of 3 How to Replace Pants Pockets, Pocket: step 1, image 3 of 3
      • Pull the damaged pocket lining out so you can see where it attaches to the pants.
      • Use sewing scissors to cut along the edge of the pocket while keeping it intact.
      • Remove the cutout pocket and keep it for the next step.
      Ask FixBot
    2. How to Replace Pants Pockets: step 2, image 1 of 2 How to Replace Pants Pockets: step 2, image 2 of 2
      • Carefully cut along the stitched edge of the pocket.
      • Lay the pocket out flat on the table.
      Ask FixBot
    3. How to Replace Pants Pockets: step 3, image 1 of 3 How to Replace Pants Pockets: step 3, image 2 of 3 How to Replace Pants Pockets: step 3, image 3 of 3
      • Lay the cutout of the old pocket over the fabric you're using for the new pocket.
      • Use a ruler to measure half an inch around the pocket’s edges to allow room for sewing the seam.
      • Use a fabric marker or chalk to trace around the pocket.
      • Ensure the outline is clearly visible to help guide the cutting or sewing process.
      Ask FixBot
    4. How to Replace Pants Pockets: step 4, image 1 of 3 How to Replace Pants Pockets: step 4, image 2 of 3 How to Replace Pants Pockets: step 4, image 3 of 3
      • Use sewing scissors to cut along the outline you've drawn.
      Ask FixBot
    5. How to Replace Pants Pockets: step 5, image 1 of 3 How to Replace Pants Pockets: step 5, image 2 of 3 How to Replace Pants Pockets: step 5, image 3 of 3
      • If you’re not familiar with how to thread a needle, please refer to this video How to Thread a Needle. It provides clear, beginner-friendly instructions to help you get started.
      • Fold the new fabric in half.
      • Begin stitching at the corner of the edge.
      Ask FixBot
    6. How to Replace Pants Pockets: step 6, image 1 of 3 How to Replace Pants Pockets: step 6, image 2 of 3 How to Replace Pants Pockets: step 6, image 3 of 3
      • Insert the needle through the edge of the fabric, pulling it through until there’s a small length of thread left on the other side.
      • Create a small loop by bringing the needle back through the fabric near the same spot.
      • Pull the thread gently but firmly to tighten the loop.
      • Continue stitching along the edge, spacing each loop about ¼ inch apart to create a strong hold.
      • Keep your stitches close together to prevent gaps and make the pocket more durable.
      Ask FixBot
    7. How to Replace Pants Pockets: step 7, image 1 of 3 How to Replace Pants Pockets: step 7, image 2 of 3 How to Replace Pants Pockets: step 7, image 3 of 3
      • Once you’ve finished stitching the edge, create a final loop, just like tying a shoelace.
      • Pass the needle through the loop and pull it tight to form a knot.
      • Repeat the knot at least once more to ensure it stays secure.
      • Use scissors to carefully trim the extra thread, leaving about ¼ inch to prevent the knot from unraveling.
      Ask FixBot
    8. How to Replace Pants Pockets: step 8, image 1 of 3 How to Replace Pants Pockets: step 8, image 2 of 3 How to Replace Pants Pockets: step 8, image 3 of 3
      • Place the new pocket fabric inside the pants, positioning it where the original pocket was removed.
      • Make sure the fabric is evenly spread out and flat to avoid wrinkles or bunching.
      • Compare the position of the new pocket with the other pocket and the original stitch marks, to ensure it's placed correctly.
      • If you're unsure about the placement, use the cut-out pocket as a reference.
      • Use sewing pins or clips to temporarily hold the fabric in place while you prepare to sew.
      Ask FixBot
    9. How to Replace Pants Pockets: step 9, image 1 of 3 How to Replace Pants Pockets: step 9, image 2 of 3 How to Replace Pants Pockets: step 9, image 3 of 3
      • Push the needle through the pants fabric and the new pocket fabric, starting at one corner.
      • Follow the same stitching method from Step 6, creating small, even loops around the edge of the pocket.
      • Continue stitching along the entire edge, keeping your loops about ¼ inch apart for durability.
      • Make sure the needle goes through both layers of fabric each time to fully secure the pocket.
      Ask FixBot
    10. How to Replace Pants Pockets: step 10, image 1 of 1
      • Continue stitching until the new pocket is connected to the pants.
      • Once finished, gently tug along the edge to check that the stitches are secure and evenly tightened.
      • If any areas feel loose, go back and reinforce them using the same stitching method.
      • Remove any sewing pins or clips still holding the pocket in place to avoid injury.
      • Give the pocket a final check for alignment, strength, and comfort.
      • A second round of stitching around stress points (like corners) can add extra durability.
      Ask FixBot
  • If your new pocket feels loose, repeat Steps 6 and 7 to reinforce the stitching.
  • Take your time with the finishing touches to ensure the pocket is securely attached.
Lucca Sa
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 65
Past 30 Days: 234
All Time: 2,064
