How to Repair an Apple Lightning Cable
    1. How to Repair an Apple Lightning Cable, How to Repair an Apple Lightning Cable: step 1, image 1 of 3 How to Repair an Apple Lightning Cable, How to Repair an Apple Lightning Cable: step 1, image 2 of 3 How to Repair an Apple Lightning Cable, How to Repair an Apple Lightning Cable: step 1, image 3 of 3
      • Locate the damaged area of your lightning cable.
      • Damage may differ from user-to-user.
      • Use the 1.6 mm gauge on the wire strippers to strip a small portion of the outer jacket.
      • Peel the outer jacket from both sides of the damaged area, exposing the underlying metal jacket.
      Ask FixBot
    2. How to Repair an Apple Lightning Cable: step 2, image 1 of 3 How to Repair an Apple Lightning Cable: step 2, image 2 of 3 How to Repair an Apple Lightning Cable: step 2, image 3 of 3
      • Carefully strip the metal jacket away from the underlying wires using the 1.0 mm gauge.
      • Use the scissors to cut the metal jacket off the cable.
      • Do not cut through the wires.
      Ask FixBot
    3. How to Repair an Apple Lightning Cable: step 3, image 1 of 2 How to Repair an Apple Lightning Cable: step 3, image 2 of 2
      • Separate and examine the three main wires for any damage. Red (Power), White (Data), and Green (Data).
      • Separate the damaged wire from the other wires.
      Ask FixBot
    4. How to Repair an Apple Lightning Cable: step 4, image 1 of 2 How to Repair an Apple Lightning Cable: step 4, image 2 of 2
      • Strip the wire around the damaged area using the 0.6 mm gauge and expose the copper wires underneath.
      Ask FixBot
    5. How to Repair an Apple Lightning Cable: step 5, image 1 of 2 How to Repair an Apple Lightning Cable: step 5, image 2 of 2
      • Solder the exposed wires together, ensuring contact throughout the damaged area using the soldering iron.
      • Repeat for any other damaged wires.
      • Soldering guns reach very high temperatures. Inappropriate use may result in injuries.
      • To learn how to solder, follow the link on How To Solder and Desolder Connections.
      Ask FixBot
    6. How to Repair an Apple Lightning Cable: step 6, image 1 of 2 How to Repair an Apple Lightning Cable: step 6, image 2 of 2
      • Wrap the soldered part of the wire in a thin layer of electrical tape to insulate it from the other wires.
      • Repeat for all soldered wires.
      Ask FixBot
    7. How to Repair an Apple Lightning Cable: step 7, image 1 of 2 How to Repair an Apple Lightning Cable: step 7, image 2 of 2
      • Slide the shrink tubing over the exposed wires to cover the bare wires on both ends.
      Ask FixBot
    8. How to Repair an Apple Lightning Cable: step 8, image 1 of 2 How to Repair an Apple Lightning Cable: step 8, image 2 of 2
      • Use the lighter to shrink the tubing around the lightning cable.
      • Straighten out the cable as you apply heat to the heat shrink tubing.
      Ask FixBot
Repeat for any other damaged areas on lightning cable.
Redacted
184 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 33
Past 30 Days: 133
All Time: 1,725
