How to Repair a Warped LP Record
  1. How to Repair a Warped LP Record, How to Repair a Warped LP Record: step 1, image 1 of 3 How to Repair a Warped LP Record, How to Repair a Warped LP Record: step 1, image 2 of 3 How to Repair a Warped LP Record, How to Repair a Warped LP Record: step 1, image 3 of 3
    • Pull your record out of its case, and make sure it is nice and clean.
    • If your record is dirty, you'll want to clean it before starting.
    • Place your clean record in the center of one of the glass panels.
  2. How to Repair a Warped LP Record: step 2, image 1 of 2 How to Repair a Warped LP Record: step 2, image 2 of 2
    • Gently set the second glass panel on top of the record.
  3. How to Repair a Warped LP Record: step 3, image 1 of 2 How to Repair a Warped LP Record: step 3, image 2 of 2
    • Preheat the oven to warm, or 175 degrees Fahrenheit (or 80 Celsius).
  4. How to Repair a Warped LP Record: step 4, image 1 of 3 How to Repair a Warped LP Record: step 4, image 2 of 3 How to Repair a Warped LP Record: step 4, image 3 of 3
    • Glass can shatter when it experiences temperature shock. Be sure that your glass is room temperature or slightly warm before putting it in the oven, so that it doesn't go from very cold to warm too quickly.
    • Slide your record, sandwiched between the two panels of glass, into the oven.
    • Stay with your record and watch it. If you smell anything funny or hear any strange noises, remove your record from the oven.
    • Warm your record in the oven for 2 or 3 minutes.
    • Leaving your record in the oven for longer may melt your record.
  5. How to Repair a Warped LP Record: step 5, image 1 of 1
    • Using oven mitts, pull the glass and record assembly out of the oven.
    • Remember that glass can shatter with temperature shock. Do not set your hot glass on a cold granite or tile countertop, or it may shatter!
    • Set the glass on a room temperature table or counter. To protect your surface, place the glass on a potholder or a towel.
  6. How to Repair a Warped LP Record: step 6, image 1 of 3 How to Repair a Warped LP Record: step 6, image 2 of 3 How to Repair a Warped LP Record: step 6, image 3 of 3
    • Weight the glass with heavy books or another flat, heavy object.
    • Leave the record under the weight of the glass and books until it cools completely.
    • When the record is cool, remove it from the glass panels.
Brittany McCrigler
89,017 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,198 Guides authored
Past 24 Hours: 27
Past 7 Days: 221
Past 30 Days: 776
All Time: 158,327
