How to Repair a Torn Stuffed Animal
  1. How to Repair a Torn Stuffed Animal, How to Repair a Torn Stuffed Animal: step 1, image 1 of 3 How to Repair a Torn Stuffed Animal, How to Repair a Torn Stuffed Animal: step 1, image 2 of 3 How to Repair a Torn Stuffed Animal, How to Repair a Torn Stuffed Animal: step 1, image 3 of 3
    • Gather all of your materials.
    • Pinpoint the tear in your stuffed animal.
    • Measure out the desired length of thread that will fully cover your tear.
    • The amount of thread that you use will vary depending on the size of the hole. However, it is always better to use too much thread rather than too little.
  2. How to Repair a Torn Stuffed Animal: step 2, image 1 of 1
    • Push the thread through the hole of the needle. Make sure to pull the thread all the way through.
    • Working with needles can be dangerous.
  3. How to Repair a Torn Stuffed Animal: step 3, image 1 of 2 How to Repair a Torn Stuffed Animal: step 3, image 2 of 2
    • Take both of the threads and match up their ends.
    • Double knot the two ends together.
  4. How to Repair a Torn Stuffed Animal: step 4, image 1 of 1
    • Cut off any excess thread at the end of the double knot.
  5. How to Repair a Torn Stuffed Animal: step 5, image 1 of 1
    • Bring the sewing needle to the top of the tear in the fabric.
    • Push the needle in through the interior of the fabric.
    • Putting the needle on the inside of the fabric hides the knot.
  6. How to Repair a Torn Stuffed Animal: step 6, image 1 of 3 How to Repair a Torn Stuffed Animal: step 6, image 2 of 3 How to Repair a Torn Stuffed Animal: step 6, image 3 of 3
    • Begin stitching up the tear. Bring the needle from the starting side over to the other side of the tear.
    • Push the thread through the top of the fabric.
    • Bring the needle back over to the starting side and pull it back up through the interior of the fabric once more.
  7. How to Repair a Torn Stuffed Animal: step 7, image 1 of 1
    • Continue stitching up the tear until you reach the end of the tear.
  8. How to Repair a Torn Stuffed Animal: step 8, image 1 of 1
    • On your final stitch, pull the needle and thread through the loop.
    • Repeat this step once more to make sure your knot is secure.
    • Pull the needle tight.
    • Don't pull the needle too tight so that you break your thread.
  9. How to Repair a Torn Stuffed Animal: step 9, image 1 of 1
    • Cut the end of the thread once the knot has been secured.
Gracie Campbell
1,551 Reputation
1 Guide authored
Cal Poly, Team 17-5, Green Fall 2015 Member of Cal Poly, Team 17-5, Green Fall 2015
CPSU-GREEN-F15S17G5
4 Members
11 Guides authored
Past 24 Hours: 36
Past 7 Days: 187
Past 30 Days: 973
All Time: 126,783
