How to Repair a Squeaky Couch
    1. How to Repair a Squeaky Couch, How to Repair a Squeaky Couch: step 1, image 1 of 1
      • Before you begin the repair, sit on the couch to identify the squeaky area.
      Ask FixBot
    2. How to Repair a Squeaky Couch: step 2, image 1 of 1
      • Carefully turn the couch over so the bottom is accessible.
      • Place it on a soft surface, such as a blanket or rug, to protect the upholstery.
      • To avoid injury, this step should be performed with two or more people.
      Ask FixBot
    3. How to Repair a Squeaky Couch: step 3, image 1 of 1
      • Use an upholstery stapler remover tool to remove the staples securing the dust cover.
      • Peel the cover back only as much as needed to access the area where the squeak is occurring.
      Ask FixBot
    4. How to Repair a Squeaky Couch: step 4, image 1 of 1
      • Before applying the lubricant, place a towel or rag beneath and around the area to prevent lubricant from getting on other parts of the couch.
      • Apply a suitable lubricant directly to the squeaking springs and any contact points where metal parts rub together.
      • Move the springs slightly to help distribute the lubricant evenly.
      • Depending on the couch and the source of the squeak, you may need to apply the grease to other components, or different springs.
      Ask FixBot
    5. How to Repair a Squeaky Couch: step 5, image 1 of 2 How to Repair a Squeaky Couch: step 5, image 2 of 2
      • Pull the dust cover tight, align it with its original staple holes if possible, then secure it using an upholstery staple gun.
      Ask FixBot
    6. How to Repair a Squeaky Couch: step 6, image 1 of 1
      • Carefully return the couch to its upright position.
      • This step should ideally be done with two or more people.
      • Sit on several areas of the couch while applying pressure to verify the squeak is gone.
      • If the squeaking persist, be prepared to wait a day or two for the effects of the grease to fully settle.
      Ask FixBot
After completing these steps, test the couch to see if the squeaking has improved. While you may notice an immediate difference, keep in mind that the lubricant can take some time to fully work its way into the springs and contact points. In my personal experience, it took about 2–3 days for the squeaking to disappear completely. If the noise persists after a few days, inspect the couch again to make sure you've treated the correct springs or to check for any loose frame components that may also need attention.
Blue Bryan
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 70
Past 30 Days: 249
All Time: 300
