How to Repair a Ripped Ribbon Choker
  1. How to Repair a Ripped Ribbon Choker, Crimp Replacement: step 1, image 1 of 3 How to Repair a Ripped Ribbon Choker, Crimp Replacement: step 1, image 2 of 3 How to Repair a Ripped Ribbon Choker, Crimp Replacement: step 1, image 3 of 3
    • Use a pair of scissors to cut right before the tear.
    • Cut off the crimp on the other end.
    • Try to cut off the least amount of fabric.
    • If you cut off too much fabric, the choker will no longer fit around your neck.
  2. How to Repair a Ripped Ribbon Choker: step 2, image 1 of 3 How to Repair a Ripped Ribbon Choker: step 2, image 2 of 3 How to Repair a Ripped Ribbon Choker: step 2, image 3 of 3
    • Using the long nose pliers, place the new crimp to the end of the ribbon and squeeze the crimp shut.
    • Make sure that the crimp is securely attached in place by pinching the crimp hard.
  3. How to Repair a Ripped Ribbon Choker: step 3, image 1 of 3 How to Repair a Ripped Ribbon Choker: step 3, image 2 of 3 How to Repair a Ripped Ribbon Choker: step 3, image 3 of 3
    • Repeat step 2 to the other end of the ribbon to complete attaching the crimps.
  4. How to Repair a Ripped Ribbon Choker: step 4, image 1 of 2 How to Repair a Ripped Ribbon Choker: step 4, image 2 of 2
    • Using the long nose pliers, open up the circular ring attached to the new clasp.
    • You can manually open up the ring with your hands if it is difficult to open with the pliers.
  5. How to Repair a Ripped Ribbon Choker: step 5, image 1 of 3 How to Repair a Ripped Ribbon Choker: step 5, image 2 of 3 How to Repair a Ripped Ribbon Choker: step 5, image 3 of 3
    • Place the open ring on the crimp by putting it through the hole on the end of the choker.
    • Using your fingers, secure the clasp by squeezing and closing the ring shut.
    • This step can be tricky because of how small the ring is. Use one hand to hold and keep the ring from moving while your other hand squeezes it shut.
    • If you cannot squeeze the ring shut, you can use your long nose pliers to squeeze and secure the ring.
  6. How to Repair a Ripped Ribbon Choker: step 6, image 1 of 2 How to Repair a Ripped Ribbon Choker: step 6, image 2 of 2
    • Use the long nose pliers to open up the circular ring attached to the chain.
    • Similar to step 4 and 5, you can use your hands instead of the long nose pliers if it is easier for you to open the ring.
  7. How to Repair a Ripped Ribbon Choker: step 7, image 1 of 3 How to Repair a Ripped Ribbon Choker: step 7, image 2 of 3 How to Repair a Ripped Ribbon Choker: step 7, image 3 of 3
    • Place the open ring on the crimp by putting it through the hole on the end.
    • Using either the long nose pliers or your hands, secure the ring of the chain to the other side of the crimp.
  8. How to Repair a Ripped Ribbon Choker: step 8, image 1 of 2 How to Repair a Ripped Ribbon Choker: step 8, image 2 of 2
    • Check the following before wearing your newly fixed ribbon choker.
    • Test out your new choker by putting it on.
    • When wearing the choker, make sure that the crimp, clasp and chain is secure.
    • If the crimp, clasp, or chain feels loose, take the choker off and retighten the rings and crimps to ensure that it will not fall off.
Janel Padaoan
172 Reputation
1 Guide authored
UC Davis, Team S2-G6, Bender Fall 2018 Member of UC Davis, Team S2-G6, Bender Fall 2018
UCD-BENDER-F18S2G6
2 Members
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 1,101
