How to Repair a Leather Jacket Pocket
  1. How to Repair a Leather Jacket Pocket, How to Repair a Leather Jacket Pocket: step 1, image 1 of 3 How to Repair a Leather Jacket Pocket, How to Repair a Leather Jacket Pocket: step 1, image 2 of 3 How to Repair a Leather Jacket Pocket, How to Repair a Leather Jacket Pocket: step 1, image 3 of 3
    • Lay the jacket flat and gather your scissors, needle, and thread.
    • If your jacket has a thicker material, you may consider using a thicker leather needle.
    • Be careful not to prick your fingers with the sharp tools listed above.
  2. How to Repair a Leather Jacket Pocket: step 2, image 1 of 2 How to Repair a Leather Jacket Pocket: step 2, image 2 of 2
    • Insert thread inside the eye of the needle.
    • Measure thread out to two times the length that you need and then use scissors to cut the thread.
    • We used white thread for this guide, but any color of thread will work for this project.
  3. How to Repair a Leather Jacket Pocket: step 3, image 1 of 3 How to Repair a Leather Jacket Pocket: step 3, image 2 of 3 How to Repair a Leather Jacket Pocket: step 3, image 3 of 3
    • Tie a knot using the two ends of the thread.
    • Repeat this knot 3 times in the same spot.
  4. How to Repair a Leather Jacket Pocket: step 4, image 1 of 3 How to Repair a Leather Jacket Pocket: step 4, image 2 of 3 How to Repair a Leather Jacket Pocket: step 4, image 3 of 3
    • At the end of the tear, insert the needle inside of the fabric's right side and pull to tighten.
    • Then, insert the needle through the front of the fabric and pull to tighten to make your first stitch.
    • You can use a safety pin to hold your fabric together if needed.
  5. How to Repair a Leather Jacket Pocket: step 5, image 1 of 2 How to Repair a Leather Jacket Pocket: step 5, image 2 of 2
    • Now that your thread is facing the inside of the fabric, insert your needle into the first layer of the left side of the fabric.
    • Weave your needle up and out through this layer and pull to tighten.
    • The thread should not be visible on the outside of the left fabric.
  6. How to Repair a Leather Jacket Pocket: step 6, image 1 of 3 How to Repair a Leather Jacket Pocket: step 6, image 2 of 3 How to Repair a Leather Jacket Pocket: step 6, image 3 of 3
    • Insert your needle into the inside of the right side of the fabric and pull to tighten. This completes your first stitch.
  7. How to Repair a Leather Jacket Pocket: step 7, image 1 of 2 How to Repair a Leather Jacket Pocket: step 7, image 2 of 2
    • To start your next stitch, insert the needle 1cm above the last puncture.
    • Repeat steps 4 through 6 until you reach the end of your tear.
  8. How to Repair a Leather Jacket Pocket: step 8, image 1 of 3 How to Repair a Leather Jacket Pocket: step 8, image 2 of 3 How to Repair a Leather Jacket Pocket: step 8, image 3 of 3
    • To finish the stitch, tie a knot by crossing the remaining thread on top of each other to make an X shape.
    • Loop the top thread inside the hole and use your thumb to hold the thread in place.
    • Make sure your needle and thread are on the inside of your fabric, or else the final knot will be visible on the outside.
  9. How to Repair a Leather Jacket Pocket: step 9, image 1 of 2 How to Repair a Leather Jacket Pocket: step 9, image 2 of 2
    • Pull the needle to tighten the knot as close to the last stitch as you can. Repeat the knot 3 times in the same spot.
  10. How to Repair a Leather Jacket Pocket: step 10, image 1 of 2 How to Repair a Leather Jacket Pocket: step 10, image 2 of 2
    • Trim the remaining thread with scissors.
    • Tuck any remaining visible thread inside the fabric.
    • You may also use a needle to tuck in the remaining visible thread.
  11. How to Repair a Leather Jacket Pocket: step 11, image 1 of 2 How to Repair a Leather Jacket Pocket: step 11, image 2 of 2
    • Wear your newly-repaired leather jacket!
Finish Line
Caitlyn
193 Reputation
1 Guide authored
UC Davis, Team 1-8, Andersen Winter 2025 Member of UC Davis, Team 1-8, Andersen Winter 2025
UCD-ANDERSEN-W25S1G8
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 28
All Time: 218
