How to Repair a Hole in a Duvet Insert
  1. How to Repair a Hole in a Duvet Insert, How to Repair a Hole in a Duvet Insert: step 1, image 1 of 1
    • Remove the duvet cover from the insert and locate the hole.
  2. How to Repair a Hole in a Duvet Insert: step 2, image 1 of 1
    • Cut a piece of scrap fabric slightly larger than the hole.
  3. How to Repair a Hole in a Duvet Insert: step 3, image 1 of 1
    • Insert the fabric inside the hole, making sure the fabric covers the entirety of the opening.
  4. How to Repair a Hole in a Duvet Insert: step 4, image 1 of 1
    • Carefully pin the patch in place, ensuring the entire opening is covered and secure.
  5. How to Repair a Hole in a Duvet Insert: step 5, image 1 of 1
    • Insert thread in the needle hole and tie a slip knot at the end of the thread.
    • Keep extra thread pulled through the needle to prevent it from unthreading. If it does, re-thread and continue.
  6. How to Repair a Hole in a Duvet Insert: step 6, image 1 of 3 How to Repair a Hole in a Duvet Insert: step 6, image 2 of 3 How to Repair a Hole in a Duvet Insert: step 6, image 3 of 3
    • Insert the needle in one of the corners of your patch, being sure to pierce through both the duvet insert and patch.
    • Continue stitching around the perimeter of the patch with stitches around 1/4 of an inch long until you have reached your previous starting point.
  7. How to Repair a Hole in a Duvet Insert: step 7, image 1 of 2 How to Repair a Hole in a Duvet Insert: step 7, image 2 of 2
    • Sew around the hole's edges to secure the duvet insert into the patch to prevent future tearing.
  8. How to Repair a Hole in a Duvet Insert: step 8, image 1 of 3 How to Repair a Hole in a Duvet Insert: step 8, image 2 of 3 How to Repair a Hole in a Duvet Insert: step 8, image 3 of 3
    • Once finished, tie 1-2 knots and cut the thread off.
    • Make sure to leave 1/4 inch between the cut and the knot to prevent the knot from coming undone.
Finish Line
2 other people completed this guide.
Ben Arnold-Galati
187 Reputation
1 Guide authored
UC Davis, Team 3-3, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 3-3, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S3G3
3 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 33
All Time: 260
