Toshiba Satellite p875 s7200 Disk Drive Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
73
All Time:
665
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
If you need to replace the disk drive, follow this guide. The disk drive can be accessed from the bottom of the computer. To replace this part, you will need a Phillips 0 screw driver and a plastic opening tool.
Parts
Tools
    1. Toshiba Satellite p875 s7200 Disk Drive Replacement, Disk Drive: step 1, image 1 of 1
      • Remember to remove any disks from the disk drive
      • Remove the battery by sliding the tabs to the left.
      • Use the spudger to lift the battery out.
      Ask FixBot
    2. Toshiba Satellite p875 s7200 Disk Drive Replacement: step 2, image 1 of 1
      • Use the Phillips head screw driver to remove the screw holding the back plate on.
      • Use the spudger to remove the back plate.
      Ask FixBot
    3. Toshiba Satellite p875 s7200 Disk Drive Replacement: step 3, image 1 of 1
      • Use the Phillips head screw driver to remove the 6mm screw holding the disk drive in.
      Ask FixBot
    4. Toshiba Satellite p875 s7200 Disk Drive Replacement: step 4, image 1 of 1
      • Removed Disk Drive.
      Ask FixBot
Danny Amado
823 Reputation
5 Guides authored
Baylor, Team S1-G3, Williams Fall 2018 Member of Baylor, Team S1-G3, Williams Fall 2018
BU-WILLIAMS-F18S1G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 73
All Time: 665
