MacBook Air 11" Mid 2012 I/O Board Cable Replacement
    1. MacBook Air 11" Mid 2012 I/O Board Cable Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      Buy
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      Ask FixBot
    2. MacBook Air 11" Mid 2012 I/O Board Cable Replacement: step 2, image 1 of 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Ask FixBot
    1. MacBook Air 11" Mid 2012 I/O Board Cable Replacement, Battery: step 3, image 1 of 2 MacBook Air 11" Mid 2012 I/O Board Cable Replacement, Battery: step 3, image 2 of 2
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
      Ask FixBot
    1. MacBook Air 11" Mid 2012 I/O Board Cable Replacement, I/O Board Cable: step 4, image 1 of 2 MacBook Air 11" Mid 2012 I/O Board Cable Replacement, I/O Board Cable: step 4, image 2 of 2
      • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
      Ask FixBot
    2. MacBook Air 11" Mid 2012 I/O Board Cable Replacement: step 5, image 1 of 2 MacBook Air 11" Mid 2012 I/O Board Cable Replacement: step 5, image 2 of 2
      • The following connector has an especially deep socket. Use care when disconnecting it.
      • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
      • Remove the I/O board cable.
      Ask FixBot
4 other people completed this guide.
Andrew Optimus Goldheart
515,789 Reputation
406 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,303 Guides authored
1 Guide Comment
You only show the basic part of the removal. You do not show how to actually remove that board. You should have shown more steps.
Steven Pierce - Reply Share
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 109
All Time: 22,190
