How to Repair a Broken Jump Ring
    1. How to Repair a Broken Jump Ring, How to Repair a Broken Jump Ring: step 1, image 1 of 1
      • Firmly grasp the broken jump ring using one set of small needle-nose pliers.
      • Make sure that the ring's opening is not blocked by the pliers.
      Ask FixBot
    2. How to Repair a Broken Jump Ring: step 2, image 1 of 1
      • Grasp the opposite side of the jump ring with your other pair of small needle noise pliers.
      Ask FixBot
    3. How to Repair a Broken Jump Ring: step 3, image 1 of 1
      • Gently twist the pliers in opposite directions until the gap is wide enough to reattach the jump ring to the ear wire.
      Ask FixBot
    4. How to Repair a Broken Jump Ring: step 4, image 1 of 2 How to Repair a Broken Jump Ring: step 4, image 2 of 2
      • Grasp the ear wire (if applicable) and insert its loop into the opening of the jump ring.
      Ask FixBot
    5. How to Repair a Broken Jump Ring: step 5, image 1 of 2 How to Repair a Broken Jump Ring: step 5, image 2 of 2
      • Insert your earring into the opening of the jump ring.
      Ask FixBot
    6. How to Repair a Broken Jump Ring: step 6, image 1 of 2 How to Repair a Broken Jump Ring: step 6, image 2 of 2
      • Grasp the jump ring between your two pairs of pliers and push/twist the two ends of the ring toward each other, until the two ends meet and the gap is closed.
      • Make sure that the gap is closed tight!
      Ask FixBot
Your earrings are ready to be worn again!
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 100
All Time: 2,073
