How to Repair Wood Dents with Wood Filler
  1. How to Repair Wood Dents with Wood Filler, How to Repair Wood Dents with Wood Filler: step 1, image 1 of 1
    • Inspect the damage and gauge how much wood filler will be needed.
    • Remember, if a big chunk is needed, then more wood filler will be needed. If it is shallow, not much wood filler will be needed.
    • This is a shallow dent, so not much wood filler is needed.
  2. How to Repair Wood Dents with Wood Filler: step 2, image 1 of 1
    • Scrape off the splinters and paint with a 50 mm wide putty knife blade.
    • Use the corner of the blade to smooth over the bumps.
  3. How to Repair Wood Dents with Wood Filler: step 3, image 1 of 1
    • Apply a medium sized amount of wood filler to the putty knife and smear onto the surface.
    • Use Elmer's Carpenter's Color Change Wood Filler.
    • Although this filler is available in various sizes, an 8 ounce can will suffice for many repairs.
  4. How to Repair Wood Dents with Wood Filler: step 4, image 1 of 1
    • Allow the filler to dry and touch it to see if it is ready for the next step.
    • Remember, the time needed to dry varies depending on the size of the damage. Shallow damages take from thirty minutes to an hour to dry, whereas deep damages take up to two hours.
    • This is a shallow damage, so it will take thirty minutes to dry.
  5. How to Repair Wood Dents with Wood Filler: step 5, image 1 of 1
    • Take a 3M 75 mm wide fine-grit sandpaper and gently sand the surface.
    • Remember to make sure the wood filler has dried before you sand the surface.
  6. How to Repair Wood Dents with Wood Filler: step 6, image 1 of 2 How to Repair Wood Dents with Wood Filler: step 6, image 2 of 2
    • Use a 25 mm stain brush to apply Minwax Wood Finish Stain to the surface of the repair.
    • Allow the stain to soak the surface for a few minutes so the wood absorbs it well.
    • An 8 ounce can of stain will suffice for this repair.
    • Optional: The 25 mm stain brush can be replaced with a regular 25 mm cloth brush found at home.
    • Optional: Paint the surface with white paint from a can of Rust-Oleum if the stain is not the desired color for the surface. Use a 25 mm paint brush, and an 8 ounce paint can will suffice. If the stain is the desired color for the surface, then painting is not necessary.
  7. How to Repair Wood Dents with Wood Filler: step 7, image 1 of 1
    • Grab a cloth towel and pat dry the surface.
    • If the stain is not the desired color, then another coat might be necessary.
    • Likewise, if the paint is not the desired color, then another coat might be necessary.
Nicole See
161 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 35
All Time: 6,039
