How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars
  1. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars, How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 1, image 1 of 1
    • Remove the main J0 head screw in the center of the binoculars, using the driver with the 4 mm bit and J0 attachment.
    Ask FixBot
  2. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 2, image 1 of 2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 2, image 2 of 2
    • Remove the top piece and the washers held under the middle screw.
    Ask FixBot
  3. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 3, image 1 of 2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 3, image 2 of 2
    • Pull the eyepieces off the binoculars.
    Ask FixBot
  4. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 4, image 1 of 2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 4, image 2 of 2
    • Remove the two side J0 head screws.
    Ask FixBot
  5. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 5, image 1 of 2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 5, image 2 of 2
    • Remove the four J0 head eyepiece screws.
    Ask FixBot
  6. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 6, image 1 of 1
    • Remove the two eyepiece plates.
    Ask FixBot
  7. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 7, image 1 of 2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 7, image 2 of 2
    • Pry apart the rear rubber covering on each side to expose the two back prism adjustment screws.
    Ask FixBot
  8. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 8, image 1 of 2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 8, image 2 of 2
    • Adjust the two 1.5 mm flat head prism screws by slightly turning the driver.
    • Note: Look through the binoculars after each turn, and if the vision is aligned, you can stop at this step. If adjusting these screws does not align the vision, proceed to Step 9.
    • DO NOT tighten the prism screws too much, or you will crack the prism and permanently destroy it. Repairing or replacing the prism is beyond the scope of this guide.
    Ask FixBot
  9. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 9, image 1 of 1
    • Unscrew the two front objective lenses by hand.
    Ask FixBot
  10. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 10, image 1 of 2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 10, image 2 of 2
    • Unscrew the two J0 head front screws.
    Ask FixBot
  11. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 11, image 1 of 1
    • Remove the two front plates.
    Ask FixBot
  12. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 12, image 1 of 2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 12, image 2 of 2
    • Peel back the front rubber coverings on both sides.
    Ask FixBot
  13. How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 13, image 1 of 2 How to Repair Double Vision on Barska 10x50 Wide-Angle Binoculars: step 13, image 2 of 2
    • Adjust the two front 1.5 mm flat head prism screws with small turns.
    • Look through the binoculars after each adjustment to see if it is aligning the vision, and repeat the adjustments until it is repaired.
    • You may need to return to Step 8 to fine-tune the other set of screws. All four prism adjustment screws must be in their correct positions to produce the correct view through the binoculars.
    Ask FixBot
4 other people completed this guide.
James Silva
241 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 37
Past 30 Days: 223
All Time: 8,079
