How to Repair Doll Eyes
    1. How to Repair Doll Eyes, How to Repair Doll Eyes: step 1, image 1 of 2 How to Repair Doll Eyes, How to Repair Doll Eyes: step 1, image 2 of 2
      • Remove the doll's head by loosening the neck strings.
      • To loosen the neck strings, turn the doll's head from left to right occasionally pulling the head until you are able to fully pull its head away from the body of the doll.
      • Make sure to remove any fiber fill inside the doll, if it contains the material.
      Ask FixBot
    2. How to Repair Doll Eyes: step 2, image 1 of 1
      • Put on disposable gloves.
      • Hold the doll head by the hair so the opening of the head is easily accessible.
      • Pour boiling water into the head and wait for 5 minutes.
      • Pour the hot water out of the doll head.
      Ask FixBot
    3. How to Repair Doll Eyes: step 3, image 1 of 1
      • Insert your finger into the doll's head and gently push the eye out from the inside.
      • A dowel rod can also be used but you must be gentle.
      • Careful as the doll's head is very hot!
      Ask FixBot
    4. How to Repair Doll Eyes: step 4, image 1 of 1
      • Separate the eyes into the individual parts.
      • Place the parts onto a towel to cool.
      Ask FixBot
    5. How to Repair Doll Eyes: step 5, image 1 of 1
      • Rinse the pieces with water and dry them with a towel.
      • Put the eyes back together.
      • After reconstructing the eyes ensure that the they are working properly. Do this by facing the eyeball to the ceiling to close the eyes and facing them towards you to open them.
      Ask FixBot
    6. How to Repair Doll Eyes: step 6, image 1 of 1
      • Repeat step 2.
      Ask FixBot
    7. How to Repair Doll Eyes: step 7, image 1 of 1
      • Make sure that both the doll's face and the eye sockets are dry before putting the eyes back in.
      • Lay the head flat and place the eye into the eye hole.
      • Push the eye straight down into the hole.
      Ask FixBot
    8. How to Repair Doll Eyes: step 8, image 1 of 1
      • Use tweezers to position the eye by grabbing onto the metal part.
      • Avoid using the eyelid to prevent damage.
      • Repeat steps 7-8 for the other eye (if applicable) while the head is still hot.
      • Make some final adjustments to make sure the eyes are positioned correctly.
      Ask FixBot
    9. How to Repair Doll Eyes: step 9, image 1 of 1
      • Check if the eyes open and close.
      • Congratulations, you have successfully repaired your doll’s eyes!
      Ask FixBot
Finish Line
Katsa Bejemil
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 57
Past 30 Days: 268
All Time: 2,458
