Dell Precision M6400 KeyBoard Replacement
  1. Dell Precision M6400 KeyBoard Replacement, Battery: step 1, image 1 of 1
    • Slide the battery release latch and remove the battery.
  2. Dell Precision M6400 KeyBoard Replacement, Base Cover: step 2, image 1 of 1
    • Remove the two M2 x 3-mm screws.
    • Slide the cover toward the front of the computer to release the tabs from the base assembly.
    • Remove the cover from the base assembly.
  3. Dell Precision M6400 KeyBoard Replacement, LED Cover: step 3, image 1 of 1
    • Starting on the left, gently lift the LED cover and disconnect the power cable and the biometer cable if present.
  4. Dell Precision M6400 KeyBoard Replacement, KeyBoard: step 4, image 1 of 1
    • Remove the four M2 x 3-mm screws along the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time- consuming to replace. Exercise care when removing and handling the keyboard.
    • Use the metal pull tabs to gently slide the keyboard toward the back of the computer to disconnect the keyboard.
Johnathan Hammond
46,110 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
1,998 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 22
All Time: 1,163
