How to Remove Scratches from a Car's Interior
  1. How to Remove Scratches from a Car's Interior, How to Remove Scratches from a Car's Interior: step 1, image 1 of 2 How to Remove Scratches from a Car's Interior, How to Remove Scratches from a Car's Interior: step 1, image 2 of 2
    • Clean the area around the scratch with the interior cleaner.
    • By removing the dirt, you will keep the debris from melting into the plastic and it will result in a smooth finish.
  2. How to Remove Scratches from a Car's Interior: step 2, image 1 of 2 How to Remove Scratches from a Car's Interior: step 2, image 2 of 2
    • Using the heat gun, gently apply heat to the plastic until it begins to soften.
    • Don't leave it on too long or else the plastic will burn and warp.
    • The plastic is ready for molding when it loses its texture and becomes slightly glossy.
  3. How to Remove Scratches from a Car's Interior: step 3, image 1 of 1
    • Apply the grain pad to the intended area using light pressure.
    • This should smooth out the scratch and will give a textured finish that will blend in with the rest of the panel.
    • Make sure you use a grain pad that closely resembles the trim of your car.
  4. How to Remove Scratches from a Car's Interior: step 4, image 1 of 1
    • Let the area cool and harden.
    • The texture should now look similar to the unaffected area.
  5. How to Remove Scratches from a Car's Interior: step 5, image 1 of 1
    • Use a super- fine grain sandpaper to sand out the area, making it smooth and authentic looking.
  6. How to Remove Scratches from a Car's Interior: step 6, image 1 of 1
    • Clean and dry the area again using the same method as in step 1 (the interior cleaner) and you're done!
By following these steps you will be able to remove scratches from your cars interior.
4 Guide Comments
what brand of grain pads do you recommend? having a difficult time finding them onlinw
Ron Beyer - Reply
Any luck finding “grain texture” pads?
ChrisB - Reply
i cant find any Grain pads / stamps online
Flow_Fire - Reply
have someone tried this trick and made it work?
Munir Ahmed - Reply
Past 24 Hours: 42
Past 7 Days: 274
Past 30 Days: 1,335
All Time: 130,081
