How to Remove Grease Buildup on Cookware
View statistics:
Past 24 Hours:
7
Past 7 Days:
43
Past 30 Days:
173
All Time:
422
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Grease buildup can reduce the performance and appearance of stainless steel cookware. This guide shows you how to remove burnt-on grease. You can use common household items like dish soap, baking soda, white vinegar, and a non-scratch sponge. This process is easy for beginners. It helps restore your cookware without harming the stainless steel surface. Wear rubber gloves if you have sensitive skin, and avoid using steel wool or abrasive scrubbers because they may scratch the cookware.
    1. How to Remove Grease Buildup on Cookware, How to Remove Grease Buildup on Cookware: step 1, image 1 of 1
      • Inspect the cookware to identify areas with heavy grease buildup.
      Ask FixBot
    2. How to Remove Grease Buildup on Cookware: step 2, image 1 of 1
      • Apply a generous amount of dish soap directly to the greasy surface.
      Ask FixBot
    3. How to Remove Grease Buildup on Cookware: step 3, image 1 of 1
      • Sprinkle baking soda evenly over the greasy surface until it is completely covered.
      • Let the baking soda sit for 5 minutes.
      Ask FixBot
    4. How to Remove Grease Buildup on Cookware: step 4, image 1 of 1
      • Slowly pour white vinegar over the baking soda until the mixture begins to fizz.
      Ask FixBot
    5. How to Remove Grease Buildup on Cookware: step 5, image 1 of 1
      • Let the mixture sit for 10–15 minutes to loosen stubborn grease.
      Ask FixBot
    6. How to Remove Grease Buildup on Cookware: step 6, image 1 of 1
      • Scrub the cookware with a non-scratch sponge using gentle circular motions until the grease begins to lift.
      • Wear gloves if you want to protect your hands.
      • Do not use steel wool or abrasive metal scrubbers, as they can scratch stainless steel cookware.
      Ask FixBot
    7. How to Remove Grease Buildup on Cookware: step 7, image 1 of 1
      • Rinse the cookware with warm water to remove all cleaning residue.
      Ask FixBot
    8. How to Remove Grease Buildup on Cookware: step 8, image 1 of 1
      • Check the cookware for any remaining grease buildup. Repeat the cleaning process if necessary.
      Ask FixBot
    9. How to Remove Grease Buildup on Cookware: step 9, image 1 of 1
      • Dry the cookware well with a clean microfiber cloth. Do this before storing it or using it again.
      Ask FixBot
Your stainless steel cookware is now clean and ready for use. Repeat these steps whenever grease buildup becomes difficult to remove.
Syretta Clayton
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 43
Past 30 Days: 173
All Time: 422
