How to Remove Cutting Board Scratches
  1. How to Remove Cutting Board Scratches, How to Remove Cutting Board Scratches: step 1, image 1 of 1
    • Thoroughly wash the cutting board with warm water and gentle dish soap.
    • Rinse the cutting board to make sure all the soap is removed.
  2. How to Remove Cutting Board Scratches: step 2, image 1 of 1
    • Pat the cutting board dry with a towel.
    • Allow the cutting board to completely air dry.
  3. How to Remove Cutting Board Scratches: step 3, image 1 of 1
    • Use a fine grit sandpaper (220-grit) and gently sand the scratched sections of the board.
    • Use even pressure until the scratches disappear.
  4. How to Remove Cutting Board Scratches: step 4, image 1 of 1
    • Remove any dust or residue using a damp towel.
    • Make sure the cutting board is completely clean and dry before moving on to the next step.
  5. How to Remove Cutting Board Scratches: step 5, image 1 of 1
    • Pour a generous amount of food-safe oil onto the surface of the board.
    • The amount will vary depending on the size of the board.
    • Allow the oil to soak into the cutting board overnight.
    • Wipe off any excess oil.
    • If there are still scratches visible on the cutting board, repeat all steps if necessary.
Finish Line
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 55
All Time: 458
