Introduction
This guide will show you how to remove a carbon build up from the engine of a 2012 VW CC. Carbon build up occurs naturally in these engines as they age as a byproduct of normal use. The buildup can cause engine roughness and even an inability to function if allowed to persist. However, it isnāt that difficult to repair!
Start the engine.
Let the engine warm up to operating temperature.
Shut the engine off.
Locate the hood latch lever under the left side of the dash on the driver side of the vehicle.
Pull the hood latch lever towards the rear of the vehicle to unlock the hood.
Apply upward pressure on the front of the hood and pull up on the plastic lever that is under the front center section of the hood.
To reassemble your vehicle, follow these instructions from step 6 to step 2 in reverse order.
2 other people completed this guide.
