How to Recognize MicroSD Card
    • The first step is to format the card on the phone to make the phone recognize it. To do this, go to the main screen, press the Center Select Key (OK)-(MENU) to open the menu.
    • Once in the menu options, there will be a Navigation Key which you will then scroll to (SETTINGS & TOOLS). Press the Center Select Key (OK).
    • From there, you will then scroll to Memory. Press the Center Select Key (OK).
    • There you will select Phone Memory, or on some models, it is labeled as (Card Memory). Scroll over to this option and once again, press the Center Select Key (OK).
    • The next step is to make sure that if you selected Phone Memory in step 4, you will also see Phone Memory Usage. Or, also to make sure that if you selected Card Memory in step 4, you will also see Card Memory Usage and Format Card.
    • Finally, Select My Pictures, My Videos, My Music, or My Sounds, and press the Center Select key (OK).
Kyle
605 Reputation
4 Guides authored
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 14
All Time: 425
