2010-2017 Suzuki Swift Trunk Light Replacement
    1. 2010-2017 Suzuki Swift Trunk Light Replacement, disconnect the battery: step 1, image 1 of 2 2010-2017 Suzuki Swift Trunk Light Replacement, disconnect the battery: step 1, image 2 of 2
      • Use the 10mm socket to disconnect the negative terminal first.
      • Disconnect the positive terminal next, also with the 10mm.
      Ask FixBot
    1. 2010-2017 Suzuki Swift Trunk Light Replacement, access the light fixture: step 2, image 1 of 3 2010-2017 Suzuki Swift Trunk Light Replacement, access the light fixture: step 2, image 2 of 3 2010-2017 Suzuki Swift Trunk Light Replacement, access the light fixture: step 2, image 3 of 3
      • Open the fixture from the trunk panel with a small flathead.
      • Turn the fixture towards you.
      • Pull out the entire fixture.
      Ask FixBot
    2. 2010-2017 Suzuki Swift Trunk Light Replacement, replace the light bulb: step 3, image 1 of 3 2010-2017 Suzuki Swift Trunk Light Replacement, replace the light bulb: step 3, image 2 of 3 2010-2017 Suzuki Swift Trunk Light Replacement, replace the light bulb: step 3, image 3 of 3
      • Push the right side of light bulb up to remove it from the fitting.
      • Insert the new bulb by pushing in one end in the flexible end of the fitting, and pushing in the other side next.
      • If you are using a LED light, make sure you turn the lights towards the lens after installation
      Ask FixBot
knipwim
16,366 Reputation
45 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 127
All Time: 842
