Introduction
Riding a bike is a great thing, but problems occur when a tire becomes flat. Flat tires can be caused by something like debris on the street that can puncture through a tire. When this happens the bicycle tube gets punctured, creates a hole, and needs to be patched. This repair guide will easily help you through how to patch your hole within seven easy steps with only a few materials needed. After patching your bike, you will be ready to go!
Using the tire lever hook side, hook the inside of the tire. Then proceed to remove the first side of the tire from the rim all along the circumference of the rim.
Once one side is out, pull the rest of the tire out in the same direction.
While squeezing the tube with both hands, rotate the tire while keeping an ear to the tube to hear air escaping, which marks the location of the hole.
Grind the location of the hole slightly until the surface feels a little rough.
Next, apply a thin coat of the rubber cement around the hole. The coat of cement should be about the same size as the patch.
For best results wait until the rubber cement is dry to the touch—around three minutes.
Finally, peel off the back of the patch, place it over the area of rubber cement with the hole centered, and then apply pressure with thumb until rubber cement is dry.
Using one hand to hold the rim, use the other to push one side of the tire back onto the rim.
Starting by placing the valve stem into the hole in the rim, begin pushing the tube into and under the tire. Then continue all the way around the tire.
Once the tube is in, push the second side of the tire into the rim and continue all the way around the rim until the tire is inside the rim.
