How to Patch Back Pants Pocket
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
42
Past 30 Days:
218
All Time:
1,287
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If you've ripped your back pocket with a tear large enough for objects to fall out here is alternative solution to just throwing out the pants. Let's reduce our waste textile together! This guide provides a step-by-step procedure on how to repair a ripped back pant pocket by hand sewing a patch of fabric on the inside of the pocket.
    1. How to Patch Back Pants Pocket, How to Patch Back Pants Pocket: step 1, image 1 of 3 How to Patch Back Pants Pocket, How to Patch Back Pants Pocket: step 1, image 2 of 3 How to Patch Back Pants Pocket, How to Patch Back Pants Pocket: step 1, image 3 of 3
      • Use a seam ripper to detach the pocket from the pants, working around the perimeter.
      Ask FixBot
    2. How to Patch Back Pants Pocket: step 2, image 1 of 3 How to Patch Back Pants Pocket: step 2, image 2 of 3 How to Patch Back Pants Pocket: step 2, image 3 of 3
      • Make your patch by cutting a piece of fabric to size.
      • It should be slightly larger than the tear on all sides.
      Ask FixBot
    3. How to Patch Back Pants Pocket: step 3, image 1 of 3 How to Patch Back Pants Pocket: step 3, image 2 of 3 How to Patch Back Pants Pocket: step 3, image 3 of 3
      • Pin the patch onto the inside of the pocket to cover the tear.
      Ask FixBot
    4. How to Patch Back Pants Pocket: step 4, image 1 of 3 How to Patch Back Pants Pocket: step 4, image 2 of 3 How to Patch Back Pants Pocket: step 4, image 3 of 3
      • Hand stitch the perimeter of the patch onto the pocket.
      Ask FixBot
    5. How to Patch Back Pants Pocket: step 5, image 1 of 3 How to Patch Back Pants Pocket: step 5, image 2 of 3 How to Patch Back Pants Pocket: step 5, image 3 of 3
      • Continue to stitch around the whole pocket, and cut off the remaining thread.
      Ask FixBot
    6. How to Patch Back Pants Pocket: step 6, image 1 of 3 How to Patch Back Pants Pocket: step 6, image 2 of 3 How to Patch Back Pants Pocket: step 6, image 3 of 3
      • Remove the pins.
      Ask FixBot
    7. How to Patch Back Pants Pocket: step 7, image 1 of 3 How to Patch Back Pants Pocket: step 7, image 2 of 3 How to Patch Back Pants Pocket: step 7, image 3 of 3
      • Pin the pocket back onto the pants.
      Ask FixBot
    8. How to Patch Back Pants Pocket: step 8, image 1 of 3 How to Patch Back Pants Pocket: step 8, image 2 of 3 How to Patch Back Pants Pocket: step 8, image 3 of 3
      • Hand stitch around the perimeter of the pocket.
      • Make sure to leave the top unstitched.
      Ask FixBot
    9. How to Patch Back Pants Pocket: step 9, image 1 of 3 How to Patch Back Pants Pocket: step 9, image 2 of 3 How to Patch Back Pants Pocket: step 9, image 3 of 3
      • Once again, remove the pins.
      Ask FixBot
    10. How to Patch Back Pants Pocket: step 10, image 1 of 1
      • Enjoy your newly repaired back pant pocket!
      Ask FixBot
Finish Line
Anna
181 Reputation
1 Guide authored
UC Davis, Team 1-4, Morris Spring 2025 Member of UC Davis, Team 1-4, Morris Spring 2025
UCD-MORRIS-S25S1G4
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 42
Past 30 Days: 218
All Time: 1,287
