How to Open the Samsung Galaxy Watch5
  1. How to Open the Samsung Galaxy Watch5, Remove the watch band: step 1, image 1 of 1
    • Take your watch off the charger and power it down.
    • Remove the watch band.
  2. How to Open the Samsung Galaxy Watch5, Unfasten the back cover: step 2, image 1 of 1
    • Use a Tri-point Y00 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
  3. How to Open the Samsung Galaxy Watch5, Pry the back cover: step 3, image 1 of 2 How to Open the Samsung Galaxy Watch5, Pry the back cover: step 3, image 2 of 2
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to loosen the gasket and create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. How to Open the Samsung Galaxy Watch5, Disconnect the sensor flex cable: step 4, image 1 of 2 How to Open the Samsung Galaxy Watch5, Disconnect the sensor flex cable: step 4, image 2 of 2
    • Lay the watch screen-side down.
    • Carefully swing open the back cover at the gap you just created.
    • Use a spudger to disconnect the sensor flex cable from the motherboard by prying the press connector straight up from its socket.
    • During reassembly, this is a good point to turn on your device and test your repair before resealing it.
  5. How to Open the Samsung Galaxy Watch5, Remove the back cover: step 5, image 1 of 2 How to Open the Samsung Galaxy Watch5, Remove the back cover: step 5, image 2 of 2
    • Remove the back cover.
    • During reassembly:
    • Make sure the rubber gasket (marked in red) is undamaged. If damaged, replace it with a new one to maintain water resistance.
3 other people completed this guide.
Manuel Haeussermann
22,854 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,758 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 155
All Time: 4,380
