How to Mend a Tear Using Sashiko Stitching
    1. How to Mend a Tear Using Sashiko Stitching, How to Mend a Tear Using Sashiko Stitching: step 1, image 1 of 3 How to Mend a Tear Using Sashiko Stitching, How to Mend a Tear Using Sashiko Stitching: step 1, image 2 of 3 How to Mend a Tear Using Sashiko Stitching, How to Mend a Tear Using Sashiko Stitching: step 1, image 3 of 3
      • Cut away any loose threads around the tear.
      Ask FixBot
    2. How to Mend a Tear Using Sashiko Stitching: step 2, image 1 of 2 How to Mend a Tear Using Sashiko Stitching: step 2, image 2 of 2
      • Measure how big your patch should be.
      • Your patch should extend at least half an inch past the tear.
      Ask FixBot
    3. How to Mend a Tear Using Sashiko Stitching: step 3, image 1 of 3 How to Mend a Tear Using Sashiko Stitching: step 3, image 2 of 3 How to Mend a Tear Using Sashiko Stitching: step 3, image 3 of 3
      • Cut your patch using measurements from Step 2.
      • You can use any sturdy fabric for your patch.
      Ask FixBot
    4. How to Mend a Tear Using Sashiko Stitching: step 4, image 1 of 3 How to Mend a Tear Using Sashiko Stitching: step 4, image 2 of 3 How to Mend a Tear Using Sashiko Stitching: step 4, image 3 of 3
      • Pin your patch to the inside of the garment.
      • Make sure the patch is centered on the tear.
      • Be careful pushing pins through to not poke yourself.
      Ask FixBot
    5. How to Mend a Tear Using Sashiko Stitching: step 5, image 1 of 3 How to Mend a Tear Using Sashiko Stitching: step 5, image 2 of 3 How to Mend a Tear Using Sashiko Stitching: step 5, image 3 of 3
      • Flip the garment right side out.
      • Over the patch, mark small dashes every half inch, horizontally and vertically.
      • These marks should create small crosses to guide your stitches later on.
      • We used a regular ballpoint pen in this step, but for a less permanent mark we recommend using tailor’s chalk or specific fabric pens that will wash out.
      Ask FixBot
    6. How to Mend a Tear Using Sashiko Stitching: step 6, image 1 of 2 How to Mend a Tear Using Sashiko Stitching: step 6, image 2 of 2
      • Thread your needle and pull the thread through at least 5 inches.
      • Wetting and pinching the end of the thread can help fit the thread through the eye of the needle.
      Ask FixBot
    7. How to Mend a Tear Using Sashiko Stitching: step 7, image 1 of 1
      • Cut the thread to a single arm’s length.
      • The length should be manageable to you; shorter is better than longer.
      Ask FixBot
    8. How to Mend a Tear Using Sashiko Stitching: step 8, image 1 of 3 How to Mend a Tear Using Sashiko Stitching: step 8, image 2 of 3 How to Mend a Tear Using Sashiko Stitching: step 8, image 3 of 3
      • Tie a double knot at the end of your thread.
      • Trim off any excess.
      Ask FixBot
    9. How to Mend a Tear Using Sashiko Stitching: step 9, image 1 of 3 How to Mend a Tear Using Sashiko Stitching: step 9, image 2 of 3 How to Mend a Tear Using Sashiko Stitching: step 9, image 3 of 3
      • Start your stitch from the inside of the garment, beginning at the top right horizontal stitch.
      Ask FixBot
    10. How to Mend a Tear Using Sashiko Stitching: step 10, image 1 of 3 How to Mend a Tear Using Sashiko Stitching: step 10, image 2 of 3 How to Mend a Tear Using Sashiko Stitching: step 10, image 3 of 3
      • Start your horizontal stitch, going over the marks, and under the gaps.
      Ask FixBot
    11. How to Mend a Tear Using Sashiko Stitching: step 11, image 1 of 3 How to Mend a Tear Using Sashiko Stitching: step 11, image 2 of 3 How to Mend a Tear Using Sashiko Stitching: step 11, image 3 of 3
      • After a couple stitches, pull your needle and thread all the way through.
      • Smooth out your stitches to avoid bunching.
      Ask FixBot
    12. How to Mend a Tear Using Sashiko Stitching: step 12, image 1 of 3 How to Mend a Tear Using Sashiko Stitching: step 12, image 2 of 3 How to Mend a Tear Using Sashiko Stitching: step 12, image 3 of 3
      • Repeat steps 10 and 11 until you reach the end of the first row.
      Ask FixBot
    13. How to Mend a Tear Using Sashiko Stitching: step 13, image 1 of 3 How to Mend a Tear Using Sashiko Stitching: step 13, image 2 of 3 How to Mend a Tear Using Sashiko Stitching: step 13, image 3 of 3
      • On the last stitch of a row, stitch down to start the next row.
      • You may need to rotate the garment between rows to make stitching easier.
      Ask FixBot
    14. How to Mend a Tear Using Sashiko Stitching: step 14, image 1 of 3 How to Mend a Tear Using Sashiko Stitching: step 14, image 2 of 3 How to Mend a Tear Using Sashiko Stitching: step 14, image 3 of 3
      • Repeat steps 10 through 13 until all horizontal stitches are done.
      • On the last stitch, push the needle through to the inside of the garment.
      Ask FixBot
    15. How to Mend a Tear Using Sashiko Stitching: step 15, image 1 of 2 How to Mend a Tear Using Sashiko Stitching: step 15, image 2 of 2
      • Remove the pins from the patch.
      Ask FixBot
    16. How to Mend a Tear Using Sashiko Stitching: step 16, image 1 of 3 How to Mend a Tear Using Sashiko Stitching: step 16, image 2 of 3 How to Mend a Tear Using Sashiko Stitching: step 16, image 3 of 3
      • Make a small stitch through just the patch, right next to where the needle came through.
      • Pull the thread almost all the way through, leaving a small loop.
      Ask FixBot
    17. How to Mend a Tear Using Sashiko Stitching: step 17, image 1 of 2 How to Mend a Tear Using Sashiko Stitching: step 17, image 2 of 2
      • Pull the needle through the loop twice.
      Ask FixBot
    18. How to Mend a Tear Using Sashiko Stitching: step 18, image 1 of 3 How to Mend a Tear Using Sashiko Stitching: step 18, image 2 of 3 How to Mend a Tear Using Sashiko Stitching: step 18, image 3 of 3
      • Pull the thread tight to knot off.
      • Trim any excess thread.
      Ask FixBot
    19. How to Mend a Tear Using Sashiko Stitching: step 19, image 1 of 3 How to Mend a Tear Using Sashiko Stitching: step 19, image 2 of 3 How to Mend a Tear Using Sashiko Stitching: step 19, image 3 of 3
      • Begin your vertical stitches, starting at the top right corner.
      • You may need to start a new thread; see Steps 6-8.
      Ask FixBot
    20. How to Mend a Tear Using Sashiko Stitching: step 20, image 1 of 3 How to Mend a Tear Using Sashiko Stitching: step 20, image 2 of 3 How to Mend a Tear Using Sashiko Stitching: step 20, image 3 of 3
      • Repeat Steps 10-13 along your vertical stitch marks.
      Ask FixBot
    21. How to Mend a Tear Using Sashiko Stitching: step 21, image 1 of 3 How to Mend a Tear Using Sashiko Stitching: step 21, image 2 of 3 How to Mend a Tear Using Sashiko Stitching: step 21, image 3 of 3
      • On your last stitch, push your needle through to the inside.
      Ask FixBot
    22. How to Mend a Tear Using Sashiko Stitching: step 22, image 1 of 2 How to Mend a Tear Using Sashiko Stitching: step 22, image 2 of 2
      Ask FixBot
    23. How to Mend a Tear Using Sashiko Stitching: step 23, image 1 of 2 How to Mend a Tear Using Sashiko Stitching: step 23, image 2 of 2
      Ask FixBot
    24. How to Mend a Tear Using Sashiko Stitching: step 24, image 1 of 2 How to Mend a Tear Using Sashiko Stitching: step 24, image 2 of 2
      Ask FixBot
You have now successfully mended your garment! Revisit this guide to mend other garments with any holes or tears.
TaShun Blanchard
352 Reputation
1 Guide authored
UC Davis, Team 3-5, Andersen Winter 2025 Member of UC Davis, Team 3-5, Andersen Winter 2025
UCD-ANDERSEN-W25S3G5
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 13
Past 7 Days: 130
Past 30 Days: 413
All Time: 2,106
